20 Most Recent
Kodak Easyshare Printer G600 Thermo Printer Questions & Answers
Cant upload pictures from my printer/camera to my computer
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
First time i've used print dock g600. prints
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
The paper keeps jamming
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Can not remove ink cartridge in Kodak EasyShare Printer Dock
Turn the power off. Hold down the transfer button, on the left side, and at the same time hold down the left arrow button, on the right side. Holding both buttons, turn power on. You should hear it recycle. After it stops, push in the cartridge in until it locks. Then you should be able to release the catch and remove the cartridge. I had the same problem, found this on the web and it worked for me. Hope it does for you, too.
Hi, I have a problem a paper is stucked in the
Please go to
this link to see a video with instructions for clearing a paper jam on your printer, and remove the paper from the rear slot if it doesn't eject automatically when you follow the instructions.
If you have further problems,
here is the home support page for your model.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
I get a
Check the two electrical contacts on the ink cartridge for small marks, which should appear if the ink cartridge was installed correctly.
If the electrical contacts do not have small marks:
1. Re-install the ink cartridge, making sure you press down on it until it clicks into position.
2. Remove the black ink cartridge, then check the two electrical contacts on the cartridge again for small marks. Repeat if necessary.
3. Re-install the ink cartridge.
Kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
Ink cartredge stuck in printer
turn off printer hold down transfer button and left arrow button at the same. Then turn in Printer, you should hear it make some noises . Open the side push on cartridge to see that it is locked in tight. Hit the green "release" button and cartridge should come loose on its own.
Will not pick up paper
Take a wet cloth and clean the front grabbing roller by rotating roller on the wet cloth. You may have to do several times and after printer has not been used for a while.
Kodak g600-paper jam
In the book they say to turn off and then turn back on that is supposed to work! ( keep trying that ) try to find a repair shop I took mine apart fixed it but not something I would do again.
