20 Most Recent
Kenmore TRIO® 77553 Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
I have a Kenmore elite Trio and the display
Hi cdb5815,
It sounds like the touchpad or the control board has
failed. There is no reset button or fuse for this problem.I recommend you go to
www.searshomeservices.com and schedule service for a Sears technician to diagnose and repair the problem.You may also want to call them at 1-800-424-2047.
Hope this helps.
Thank you for using FixYa.
I can't get my ice maker water filter to turn and lock in place
Put some Vaseline on the O-Ring to help it slide into place. Make sure it is properly inserted at the beginning.
If the filter is located inside the refrigerator:
- Turn off the ice maker.
- Push the eject button.
- Pull the filter out of the housing.
- Push the new filter into the housing until it clicks.
- Turn on the ice maker.
- Run 2 gallons of water through the water dispenser to purge air and residue.
More items...
Aug 30, 2023
1/28/2024 2:40:53 AM •
Kenmore...
Answered
on Jan 28, 2024
My Kenmore Trio refrigerator (#596.76502500)
The fan that blows cold air from the freezer to cool the refrigerator is not working. If your a little handy with tools its an easy fix. Its located in the freezer. Open your freezer door take off the steel panel at the back of the inside of the freezer. After you remove the panel you will see the fan the blows the cold air up to the Frig. A quick trip to a local appliance store for a new fan with do the trick. Put in the new fan 100% fixed even better than new because the orginal part is defective Kenmore should have recalled them. I have the same frig and its been perfect since I repaced my failed fan.
1/2/2024 3:58:28 PM •
Kenmore...
Answered
on Jan 02, 2024
