20 Most Recent
Frigidaire 9 cu. ft. / 255 liter Chest Freezer FFC09C3A Questions & Answers
Is the freezer being outside causing motor problems
Hello Donna F - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
Does it mean any thing
No. It could be green, red, white, IR, and colored light will work if it's the right wattage and the same bulb barrel, then it will workie...he,he,he,he, awesome colored lights in one freezer---never though of that before, wonderful...GB ya. stewbison
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Relay clicks, compressor doesn't start
try replacing the relay/ overload you can buy a supco replacement there's 2 of them one covers 1/15 - 1/6 and the other covers1/3 - 1/4 its really easy to wire up and cost effective. any questions don't hesitate to contact by e-mail
[email protected]
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
