20 Most Recent
Nikon ML-L3 Remote Control Questions & Answers
How to use remote control
Set the camera to a remote release mode.
If you require further assistance, please add a comment to this question and specify the model of your Nikon camera.
Can't get my ml l3 to work
Make sure the camera is set to one of the remote release modes.
If you require further assistance, please add a comment to this question and specify the model of the camera.
Nikon ML-L3 remote control working d7100
Set the camera to one of the remote modes. The quick-response remote mode fires the camera when you push the button on the remote, just as if you were pushing the shutter release button on the camera. The delayed response remote mode gives you two seconds to hide the remote behind your back before firing the camera. The remote mirror-up mode raises the mirror the first time you press the button, then fires the camera the second time to prevent camera shake.
See "Remote Control Photography" beginning on page 127 of the manual: http://download3.nikonimglib.com/archive1/jx33T00TFfqq00nXNhJ55CBmTl26/D7100_NT(En)03.pdf
I do not now how to set my remote mode on my nikon
Sorry, but the D3100 doesn't work with the ML-L3 infrared remote. It uses the MC-DC2 wired remote or equivalent.With the MC-DC2, you don't need to set a remote mode. Simply plug the MC-DC2 into the D3100. You can then use the button on the remote the same way you normally use the shutter release button on the camera.
I cannot open the remote.
Turn the unit over. You'll see two arrows marked "1" and "2". Put a fingernail into the gap between the two ridges of "1" and move in the direction indicated by the arrow. While keeping it there, put another fingernail into the slot of "2" and pull in the direction of the arrow.The procedure almost requires three hands. but it can be done with two if you put the remote down on a tabletop.
How to install a battery into my photive ML-L3 wirless shutter release remote?
Turn the unit over. You'll see two arrows marked "1" and "2". Put a fingernail into the gap between the two ridges of "1" and move in the direction indicated by the arrow. While keeping it there, put another fingernail into the slot of "2" and pull in the direction of the arrow. The procedure almost requires three hands. but it can be done with two if you put the remote down on a tabletop.
ML-L3 Wireless Remote Controller Shutter Release for Camera Nikon D5000
You need to set the release mode to one of the remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.See the "Release Mode" section of the manual (page 65 in my copy).
How to set ML-L3 to D40 Nikon
You need to set the shooting mode to one of the two remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.See the "Shooting Modes" section in the manual (page 32 in my copy).
Does ML-L3 works with D200
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help. Click open the ads posted by the side and bottom of each posts. They might help you to get more details.
The ML-L3! The laser
How do you know it's not coming on? The LED (not a laser) puts out infrared, normally not visible to the human eye. If you have a point&shoot digital camera or a dSLR with LiveView, try taking a photo of it and see whether it lights up when you press the button. It'll probably show up white. You might try a TV remote for comparison.Also, try cleaning both the LED window on the remote and the remote sensor on the camera. And make sure you're pointing the remote at the sensor.
How do i sync my ML-L3 to my Nikon D5100
Set the camera's release mode to one of the two remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.To change the release mode, press the [i] button to bring up the information display screen. Press it again to put the cursor in the info display screen. Use the cursor keys to select the release mode --- it's the fifth item from the top along the right edge of the screen --- and press the [OK] button. Use the cursor keys to highlight the desired release mode and press [OK]. To return to shooting mode, press the shutter release button halfway.Full details are in the "Release Mode" section of the manual (page 35 in my copy). If you need manual, you may download one
here.
D200 shutter release mode
The ML-L3 does not work with the D200.If you have a specific question about the D200's shutter release modes, please state it in a comment to this post.
ML3 REMOTE USERS GUIDE needed in english
Nikon really doesn't have a user's guide for the ML-L3. It comes with a slip of paper telling you how to change the battery, and that's about it. The thing only has one button on it, after all.The precise steps for using the remote vary from camera to camera. If your camera works with the ML-L3, there will be something in the camera's manual telling you how. It's usually called "Release Mode" or "Shooting Mode." Basically, you set the camera to a remote mode, then use the button on the remote instead of the shutter release button on the camera.
Ml-l3 not working
Having gone over a month without a response to my query, I assume it was simply a matter of setting the camera to a remote mode.
