20 Most Recent
Generic MID8125-4G Coby Kyros 8" Touchscreen Tablet Quantity12 Questions & Answers
My android is no longer supported by google play
There are alternative ways to download and install applications on an android mobile device without referring to "Google Play". Android application files are usually .apk files. For the case of actually downloading and installing Google Play, just search for "Google Play apk" file. Sites like "APK4Fun" have most common android application files available open to download. But using .apk files from sources other than "Google Play" isn't always a secure thing to do, so choose at your discretion. If you are having problems installing the application or even downloading it, try a PC android device manager like "MobileGo" by Wondershare. Install the application on your PC and via USB connect your android device to the PC. Make sure USB Debugging is enabled on your device and the device is sync with the PC and not just charging. Once the MobileGo program identifies your android device you can install .apk files to your android device via PC by choosing install app and finding the .apk file on you downloaded on your computer.
1/7/2020 4:36:15 AM •
Generic...
Answered
on Jan 07, 2020
Cracked screen
There are shops that repair them search in google for tablet screen repairs.
Terry
4/1/2014 10:30:19 PM •
Generic...
Answered
on Apr 01, 2014
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
4/24/2017 4:40:33 AM •
Generic...
Answered
on Apr 24, 2017
I bought my crystalview off ebay but it came with a password on it how do i hard reset it so i can use it
* Turn off your tablet
* Press and hold power+volDOWN+home
* It will turn on with a word start in it let go of the buttons you are holding
* Turn on the VolDown twice so a recovery mode will appear.
* Press power to restart in recovery mode
* After android image hold down power and then VolUP
* Scroll with volume button and use power to select "wipe data/factory reset"
* Then select "yes-erase all user data"
* Your tablet will now reboot
2/12/2014 11:37:45 PM •
Generic...
Answered
on Feb 12, 2014
AMT .COM
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
This is a free driver solutions.
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.Hope this helps
11/18/2012 6:48:18 PM •
Generic...
Answered
on Nov 18, 2012
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
