20 Most Recent
Visioneer Strobe XP 220 Flatbed Scanner Questions & Answers
My computer will not recognize
is the software that comes with the unit is compatible with windows xp? try to install the software first,be sure to finish it if ask to restart do it, before plugging the scanner, then follow the instruction on the screen,
Using xp220 when scanning automaticall
The lamp in this scanner is a CCFL tube one - it never dies. What dies is the power source that generates its high voltage. But a defect in the power source would have not allow a scan to start so it's not your problem.
Most likely is a paper movement problem - the scan starts, the paper is pulled in and it jams so the scan is cancelled. This is a known problem and Visioneer sells the required paper guide that fails
http://orders.visioneer.com/category.jsp?category=SPARES_XP220
But if you have indeed tube problems then you must take out the bottom of the scanner to access the power board and test it. But i must warn you - there are no replacement parts so either you fix it yourself or it's dead.
Visioneer RoadWarrior 4D- Calibraton Sheet, Copper Paper. I need to buy one or two of this
I cannot provide specific recommendations for where to purchase items. However, you may be able to find a calibration sheet for the Visioneer RoadWarrior 4D scanner online or through a retailer that specializes in office equipment or computer accessories. You may also want to try contacting Visioneer directly to inquire about purchasing a calibration sheet for your scanner.
Keep in mind that you may need to provide the model number and serial number of your scanner when making a request for a calibration sheet, so it may be helpful to have this information available. It is also a good idea to confirm that the calibration sheet you are purchasing is specifically designed for the Visioneer RoadWarrior 4D scanner and is made of copper paper, as this may affect its compatibility and performance.
Universal drivers
Go to Visioneer product support site support.visioneer.com/ , enter your model number and search for installation drivers
My roadwarrior 120 scanner wont install drivers i have windows 7 64
Uninstall the drivers which are already in your computer and install a fresh version of it. Try going to the website of the manufacturer to find the driver and install it in your computer.After doing that, update the drivers in your computer so that you can make sure that they'll work great. You can use RadarSync which you can get from here http://bit.ly/rsdriverI hope this helps!David
