20 Most Recent Brother PC-420 Questions & Answers
The last time mine did that I found out I had the thread running off the bobbin in the wrong direction.
Brother PC-420 | Answered on Sep 17, 2019
It's a tension issue. Sounds like too much bobbin thread is coming to the top of the fabric.
Understanding Thread Tension Threads
Brother PC-420 | Answered on Dec 18, 2017
Try resetting it according to the manual on page 56. First turn the machine off, unplug it and wait 2 - 3 minutes and re-plug it and turn it back on and reset the stitch length - the screen for the stitch setting will appear, the down arrow makes the stitch shorter, and up arrow makes the stitch longer. If that don't work you might have to contact sewing machine serviceman, or you might can call Brothers and they can help troubleshoot the problem.
Brother PC-420 | Answered on Feb 25, 2016
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Brother PC-420 | Answered on Apr 15, 2015
I am not sure what to do about it. Did you try clean the shuttle real well? If that does not work, call Brother!
Brother PC-420 | Answered on Apr 01, 2015
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Brother PC-420 | Answered on Mar 30, 2015
So many of the built in fonts and designs in these embroidery machines aren't easily manipulated. Computer digitizing software is what you want to use to get the spacing and layout correct.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Brother PC-420 | Answered on Mar 12, 2015
Can you turn the hand wheel at all ? If not, something is jammed tight somewhere.
Have you removed the bobbin from the bobbin case and cleaned thoroughly around it, removing all lint, dust, loose thread bits ?
If that does not help, can you try taking apart the shuttle assembly, which the bobbin fits into ?
Sometimes you may get thread wound around in these parts and it causes a jam. Please, observe how the parts of the shuttle assembly fit together so you know how to put it back together. There may be a small lever or pair of levers that must be moved to allow the parts to be pulled out. There aren't many, usually two or three pieces.
It's very useful to snap pics.. of it the way it looks before you touch it, and then each step as you take it apart, so you have a guide to putting it back.
It's also possible a gear is jammed. Most machines allow you to remove the upper casing and bottom casing. You'd have to take out some screws to do this. If anything is jammed between gears that you can see, remove it carefully. If you have to use a tool to pull out something jammed, take care not to damage the gear teeth, as that's a big repair job and often not worth the expense compared to buying another machine, sadly.
Brother PC-420 | Answered on Mar 04, 2015
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Brother PC-420 | Answered on Feb 23, 2015
This page should help explain that error message:
http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_pc420eus&ftype3=2207&faqid=faqh00000109_000
Brother PC-420 | Answered on Aug 05, 2014
Lift the machine, turn it upside down and shake it. That's how we do it here in the shop.
Brother PC-420 | Answered on Jul 02, 2014
Sounds like you've either got a heck of a jam going on with thread everywhere, or you've lost a gear or three.
Brother PC-420 | Answered on May 24, 2014
It should leave a thread tail 1 inch or so long, it is not supposed to be short..
Brother PC-420 | Answered on May 15, 2014
Brother PC-420 Logo
72 questions posted
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
brother pc 420 prw forgotten sew
  • Sewing Machines
