20 Most Recent Juki DDL-8300 Questions & Answers
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Juki DDL-8300 | Answered on Aug 25, 2017
I am slightly familiar with older sewing machines but not modern machines. It is a long time since I've seen my machines.
If your presser foot has a wide slot it is clearly possible to use it for zig-zag sewing. If the machine is capable of zig-zag or swing needle sewing, it is sometimes possible to swing the needle and fix it to the left or right and fix it in that position.
I suggest you check in your machine instruction manual. Perhaps the presser foot you are using is unsuitable for your machine...
Juki DDL-8300 | Answered on May 13, 2017
Visit us at www.ifixmachine.com
Juki DDL-8300 | Answered on Aug 23, 2016
Selector is either worn or broken. Probably best to take it for service.
Juki DDL-8300 | Answered on Jan 20, 2016
The fuse is typically in the electrical box where the on/off switch is .
Juki DDL-8300 | Answered on Sep 18, 2014
if its not mechanical the thread has bound up the hook. spray hook all over with oil and let sit for a day then use hand wheel to force hook to turn, u will not damage machine. gp back and forth.
Juki DDL-8300 | Answered on Jun 14, 2014
douche the hook with oil wait a day and use hand force to get machine to turn. u have thread deep inside hook and its binding the machine. u can spray with wd-40 too but use alot and let it sit.
change needle the root of almost all problems!!!
usually the other way around. belt may be worn too. u can adjust tension by screws under machine that hold motor.
hi there
if you mean mechanic parts i have parts list for DDL5550-7 it's same parts but if you need electronic parts for control box tell me the model for control box. now email me i can send parts list to you
best regards
ashraf abozid
aabozid@hotmail.com
Juki DDL-8300 | Answered on Apr 28, 2014
u need a silicon based nylon thread and a larger needle. needle may be getting hot too depending on thickness of work. spray some silicon on upper thread.
Juki DDL-8300 | Answered on Apr 11, 2014
machine out of time or wrong needle. most problems with machines involve the needle.
If the needle gets stuck with no thread, The needle is hitting something. Could be needle not up all the way or something needs adjusting. If it gets stuck with thread. It is probably an upper thread tension or threading issue.
Juki DDL-8300 | Answered on Apr 08, 2014
can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer.
a waiting your answer about control model and i will help you.
thanks
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Juki DDL-8300 | Answered on Jan 08, 2014
just send your email and i will send to you user manual for DDL-5550 , it's same DDL8300 JUKI machine.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Juki DDL-8300 | Answered on Jan 07, 2014
The first thing to try is the fuse. The best way to do this is swap the machine's fuse with that in your kettle's plug - this should also be 13 amps as on your machine.
Also, it is possible that there has been a power cut; even though these are rare they can happen, so do not dismiss this possibility.
The final thing to try is to move the cable and see if the machine will come on. If the machine comes on then you will need to contact the manufacturer for advice about their repair service
Juki DDL-8300 | Answered on Dec 13, 2013
Juki DDL-8300 Logo
131 questions posted
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
juki ddl 5550 6 e7 error code
  • Sewing Machines
