20 Most Recent
SINGER 7470 Sewing Machine Questions & Answers
Singer conferdence 7470 not sewing
Try a brand new needle. If that doesn't work, then the machine is most likely out of time. Search for sewing machine timing or take it for service.
Singer 522 speed controller capacitor has burnt.
So did mine! I found that it made the machine run even when there was no input. If that is your problem then simply open up the controller, and undo the screws to remove the burnt out component (only the burnt one, there are two in there). Reassemble, and it will work again.
Foot pedal not working
Well, you are definitely getting power from the electric plug in. Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew? If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Re-timing up
I would purchase the service manual for your machine. It shows you how to time it. I just checked Sewing Parts Online, who sells service manuals for a nominal price and while they don't have it listed, typically if you call or send them an email they can get it for you in a reasonable amount of time.
Adjust timing
Presuming your needle is clamed in fully up position & is not needle bar height problem,this needle/hook timing should get your local sewing machine technician to get it adjusted correctly.
