20 Most Recent Sansui 27" TV Questions & Answers
https://www.techwalla.com/articles/how-to-unlock-a-v-chip
The limits are to stop inappropriate content, so in a hotel reception, that is a good idea.
Try unplugging it for 10 minutes
How to Unlock Chip Techwalla com
Or phone Sansui
SANSUI PASSWORD RESET
Sansui 27" TV | Answered on Mar 02, 2018
I lost my sansui tv chic special 300 remote, can u tell me which num remote can suit for my sansui chic special 300
Sansui 27" TV | Answered on Apr 12, 2016
try default codes, e.g: 9999. Thanks for using Fixya.
Sansui 27" TV | Answered on Mar 23, 2014
Sony remote controls have no setup code for Sansui TVs.
Sansui 27" TV | Answered on Jan 16, 2013
No red color is the problem to your set. The video output section circuit, the board plugged on to the neck of the picture tube need to be troubleshooted for any defective component/s or loose solder terminals. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Pull up older posts there, and come towards the post describes about 'one color predominant screen'. You can get more details.
Sansui 27" TV | Answered on Oct 06, 2012
What is the exact model number to your Sansui TV? Check its back cover for this detail.
Sansui 27" TV | Answered on Aug 09, 2012
This fault is calle technically as 'retrace lines'. It is with an adjustment fault. Visit this site to get more details and repair help to this fault. Detailed description are given there. "Electro-help" is the site name. Search for it either by Yahoo or google. It is an electronic entertainement equipments service help site.
Sansui 27" TV | Answered on May 10, 2012
Setup codes for sansui are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Sansui 27" TV | Answered on Mar 17, 2012
a defective crt socket is most likely the defect
Sansui 27" TV | Answered on Jul 16, 2011
Turn off closed-captioning. It's on and set to "text" mode now, and the set is blanking out the area where text should go. Your remote control probably has a single button for caption settings, and it got pressed at some time. It's easy to do. Just press it again until captions are turned off and the box will be gone.
Sansui 27" TV | Answered on Jul 09, 2011
This is called vertical collapse and the most common cause is a failure of the vertical IC. If you can update this with the model number, I should be able to provide the part numbers and costs for the parts required to fix this. Also, if you intend to repair this yourself, please indicate thtat as well. The parts will cost around $20 or so.
Dan
Sansui 27" TV | Answered on Jul 03, 2011
There are several versions of this model. They all have the same problem. The problem I'm speaking of , the location numbers of bad capacitors. So I will give you values and you will need to search and replace these. Find an ESR meter to locate bad capacitors. In the vertical deflection look for 50 volts at 4.7Mf, 35 volts at 100Mfs,50 volts and 25 volts at 1 Mfs. Be sure to resolder the vertical IC and don't solder the pins together. Find the smallest electrolytic caps valued at 50 volts 1 Mfs and replace these. These are scattered through out the main board. Other small caps include the 25 volt 10 Mfs, several of these as well. You also may want to inspect the capacitors near the flyback transformer and horizontal transistor and the horizontal output transistor. You will have to seek and find the weak or bad caps here. I will tell you, the shut down is mainly a capacitor issue. Caution is required when you remove these. The circuit traces in these TVs are very delicate and you can destroy this TV in seconds.Thanks for asking me and show all hands of support!
Sansui 27" TV | Answered on Jun 12, 2011
Sansui 27" TV Logo
100 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
green blue color sansui tv
  • Televison & Video
