20 Most Recent
Fujitsu LifeBook T4220 Tablet PC Questions & Answers
Rotate image
Most image software should be able to do that for you. I use FastStone Image Viewer which also lets you crop, rotate, resize pictures. It's freeware.
Computer wont come on
Did you installed the fjsecs Security Panel Application????...http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/Security.htmRead this manual, maybe can help you.http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-02EN-00.pdf page 26To unlock the machine is completely necessary that you remind the password...Just pres the display buttons in the order that you selected in the program.http://static.phing.com/listings/48/481970/2882-8dc5j0_l.jpgThe buttons next to the power button at the right of the display.There is a microphone symbol next to the buttons....
1 = a and arrow down
2= b and arrow up
3= rotate screen button
4= fn button
ent = alt.
If you selected
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/images/Screenshots/Image5.jpg
Example:If you checked the boxes 1234 pres the buttons 123and4 at the same time.next press ent (ent is next to power button)....when you press any button that make a beep sound...If the pass is wrong it will beep constantly for one minute..other example: 1 - 2 - 14 - 4in the first just 1 press 1in the second 2 press 2in the third 1 and 4 press 1 and 4 at the same time in the fourth 4 press 4finally press the button ent.I hope you can access to your laptop....
Forgot password Fujitsu LifeBook T4220 Tablet PC
Hi,Good day! What password are you refering to? Is it the one used for logging into the unit itself?You can try the work around below.- You can try to restore the unit back to it's factory settings if you don't have any important files in the hard drive. Regards,Meir
I use windows xp profesional
You need Windows XP Tablet PC edition 2005 to be able to use the Tablet properties.If Windows XP tablet PC was the original Os installed, then you will have to reinstall it.
