20 Most Recent Lenovo Intel Centrino Pentium M 778 1.6GHz - 512MB DDR2 SDRAM - 40GB - Bluetooth, Wi-Fi, Gigabit Ethernet -... Tablet PC Questions & Answers
Desbloquear tablet pc m778
alguien me puede decir como desbloqueo mi table pc android
12/16/2013 4:15:22 AM • Lenovo Intel... • Answered on Dec 16, 2013
How to unlock my tablet pc
for me to be able to give you this information i will need to know the maker of the tablet and model
12/20/2012 11:23:36 PM • Lenovo Intel... • Answered on Dec 20, 2012
4answers
How do you transfer music from a Lenovo Yoga 10 tablet to an SD card
You can get an adapter cable that will fit into the tablet's USB port. It's called an OTG cable. With that, you can hook up cellphones, digital cameras, thumb drives, SD card readers and many more things. The best way to do that would be to get an adapter OTG cable and a card reader. You can also transfer it to a computer and then to the SD card. If you don't have a card reader most digital cameras will work as one. Hook the camera to a ps and look for it in my computer folder. (works on macs also) and opens it. There you can put any file on the SD card. If using an OTG adapter to just hook it to the device's USB port and go to your file manager app. I would recommend an app called ES File Explorer. it makes it simple to find files on Android devices. Once you locate the drive (usually it's called USBDRIVEA) just transfer the music. Here is a link to a video that will help. I take no credit of video.
3/6/2024 10:32:12 AM • Lenovo Tablets &... • Answered on Mar 06, 2024
Lenovo A1000-F will not connect to network
Hi, please attempt to use another internet source before attempt to access the app store on your tablet. This can be either ethernet or tablet. If this fails, please restart your tablet once or twice. Otherwise, you might need to transfer antivirus apps via usb into your tablet, install/run those and then attempt to access your app store again. Thank you.
12/8/2022 3:41:09 AM • Lenovo Tablets &... • Answered on Dec 08, 2022
2answers
How do i remove/delete unwanted downloaded files from my lenovo tab2 A10-30 tablet?
Go to Settings and choose Default Applications. You should be able to see the list of all of the apps which you have set as default. The only thing you have to do is click on "clear" and it will delete the unwanted setting.
1/3/2022 10:26:42 AM • Lenovo Tablets &... • Answered on Jan 03, 2022
My lenovo tablet won't let me open setting because I get message saying unfortunately google play has stopped working, does any one how to fix this problem? Can any one help
Google Play Services, the preinstalled app on your phone plays an extremely crucial role in the regular running of your lenvono. If anything is wrong with it, then your lenovo will start throwing fits in the form of errors and crashes including 'Google Play Services keeps stopping' error. To remove the error, you need to fix Play Services. Here you will find numerous ways to fix any issue related to Play Services. Let's get to know them. 1 Starting with, will actually with restarting you Lenovo. 2 Another that does wonders for any issue is to "clear the cache" and date of the particular app. In this case, we need to clear cache and data for "Google Play Services" and "Google Play Store". Doing any of that will not delete any data from your phone. However, clearing data will log you out from Play Store and reset its settings. In settings 3 "Google Play Services" is a system app, you cannot remove it from your lenovo completely. However, you can uninstall the updates, which will revert it to the factory version forcing your phone to update it automatically, thus fixing any issue. On the Google Play Services screen, tap on the "three-dot" icon at the top-right corner. Select Uninstall updates from the menu. 4 Unlike other installed apps, you don't have to update Google Play Services manually. It's done automatically in the background by your lenovo. However, sometimes, the issue is with the update itself. So you need to update it to the newer or older version manually. We have covered ots of ways to update google play service in detail. Do check that. And if you face any issue while updating it, check fixes. 6 Similar to restart, sometimes booting in the safe mode fixes various issues on an Android phone. Again, doing that will not delete you data and you can access it in safe mode as well. Running the lenovo in safe mode also helps in identifying the issues caused by the third-party apps. I hope these will get you over your issue with ease.
2/26/2021 5:13:39 AM • Lenovo Tablets &... • Answered on Feb 26, 2021
2answers
How do I disable the screen lock on lenovo M10 tablet
go to settings, security, choose none
1/5/2021 7:03:05 AM • Lenovo Tablets &... • Answered on Jan 05, 2021
I got a Lenovo Yoga Tab 3 Pro tablet which is stuck on 29% charge.
Go to Battery options on your Device settings.
Check the Battery charging mode. The device can only charge through the power adapter and may have shifted into the USB charging. If it shows USB charging, do the following.
Remove the USB connector from the Tab device and AC adapter from wall power outlet (Must need to remove both the ends).
Reconnect the USB cable and AC adapter to wall unit. Now check the charging mode, it shows charging with AC. Now the device can charge as normal condition.
If however it shows USB charging, do this step again by disconnecting the ports and reconnecting until you see the AC charging mode for Battery.
If the mode was correct, I'd test the charger unit for 5+ volts. It's possible it died.
4/22/2020 11:50:43 PM • Lenovo Tablets &... • Answered on Apr 22, 2020
Iv just bought a Lenovo tb7104 tablet it as got family link lock password on it I can't remove all the details as it's asking parents password if I factory reset so is they a way to hard rest it
To hard reset your tablet you will have to go to the recovery mode on your device and for that, you will have to Power Off your device and then click and hold on "Power and Volume Up or Down" for 2-4 seconds and after that you will feel a small vibration from your device and then leave the buttons and then you will see a recovery menu. Now using your Volume Buttons for Scrolling and Power button for selecting go to the Reset option and click on Power button and now it will ask for confirmation, click on Power button to confirm and after that, your device will do some operation and after that your device will reboot and it might take more than 4-5 minutes for the first boot so don't worry about that and now your device is successfully booted and everything is unlocked.
4/10/2019 9:15:16 AM • Lenovo Tablets &... • Answered on Apr 10, 2019
How do I get a free activation code for my Lenovo tablet. Don't have receipt
Go to Lenovo.com and enter the service tag number from the tablet.
1/8/2019 3:39:28 AM • Lenovo Tablets &... • Answered on Jan 08, 2019
I have a lenovo tablet and forgot my google account password so i hard reset the tablet and now it will not accept my google account. please i need help i just got it and now i cant use it
If you type in too YouTube Lenovo whatever model it is google bypass it will show how to do it step by step
1/7/2019 12:04:22 PM • Lenovo Tablets &... • Answered on Jan 07, 2019
I bought a lenovo tablet and I don't have box or receipt telling Mr can't activate what can I do
You have to have the box. That's were the activation code is stored. Try reaching to Lenovo to see if they would help trace your purchase.
1/2/2019 8:00:57 PM • Lenovo Tablets &... • Answered on Jan 02, 2019
How to bypass frp on lenovo tb-x103f tablet
Is this your computer or someone else that had it before you? If it is yours enter the email account and password for that before it was reset . If it was someone else that set this then it requires more work
12/31/2018 4:36:06 PM • Lenovo Tablets &... • Answered on Dec 31, 2018
How do I take a screenshot on a Lenovo TB-x 103F tablet
You didn't provide you OS, so I'm going with Android 6.0. Ajustes (Ajustes del sistema)> Sistema (Todos los ajustes)> Sistema> Idioma y entrada> Idioma Slide down and choose Ingl?s. Then simply back up.
12/26/2018 10:44:22 PM • Lenovo Tablets &... • Answered on Dec 26, 2018
How do i fix a service state that is out of service or network that is disconnected on my lenovo tablet a7600h
There is some useful way to fix it properly. But If you need the proper guidance you can easily visit the https://hpsupports.co/hp-support-assistant/ page.
11/30/2018 11:08:43 AM • Lenovo Tablets &... • Answered on Nov 30, 2018
How to unlock my lenovo tablet
Swipe the screen
11/11/2018 4:45:59 PM • Lenovo Tablets &... • Answered on Nov 11, 2018
Samsung service center trinidad
Hi Aleem, I have the number for Samsung service center in Trinidad. TRINIDAD & TOBAGO 1-800-SAMSUNG(726-7864) www.samsung.com/latin/support(Spanish) www.samsung.com/latin_en/support(English)
10/30/2018 1:26:33 AM • Lenovo Tablets &... • Answered on Oct 30, 2018
Lenovo Intel Centrino Pentium M 778 1.6GHz - 512MB DDR2 SDRAM - 40GB - Bluetooth, Wi-Fi, Gigabit Ethernet -... Tablet PC Logo
4 questions posted
Top Lenovo Tablets & eReaders Experts
NOEL
NOEL
Paul Bade
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Tablets & eReaders
Most Popular Question
desbloquear tablet pc m778
  • Tablets & eReaders
