20 Most Recent Compaq 2710p Tablet PC Questions & Answers
Hi Are you running win 7 32 bits?enterprise?
Compaq 2710p... | Answered on Nov 23, 2012
Have you tried putting in another memory card? Because it would appear that there is something wrong with your memory card. Try to use another card and see if this changes anything. If it does, then your memory card is faulty.
If you have some important data in your memory card then I suggest you contact a data recovery company.
Hope this helps.
Compaq 2710p... | Answered on May 10, 2011
1. Check ur Power Adapter, whether ur laptop get power or not.
2. if power cable and adapter ok. check system RAM
but u said it does not recognize power, So u have problem with either Power card or power plug inside laptop. and u said it deosn not recognize battery also, in this case check RAM, CPU and MB.
DO VOTE
Compaq 2710p... | Answered on Sep 24, 2010
There are 2 possible causes for that error
1 - most likely the hard disk has died. replace it and reinstall.
2 - the file system (even the one on the recovery partition) has been totally corrupted, a full reinstall from an external media is mandatory.
Compaq 2710p... | Answered on Jun 15, 2010
Go for GD229AA.
Hope i helped you.
Thanks.
Compaq 2710p... | Answered on Sep 18, 2009
I PUT A HEAT SINK FROM A CPU AND ATTACHED COOLING FAN TO THE HEAT SINK
AND THAN ATTACH IT TO THE BLACK OBLONG LONG RECTANGLE BOX LIKE OBJECT AND IT WILL STAY VERY COOL AND ALSO SAVE THE BATTARY FROM OVER HEATING AND DAMAGING THE BATTERY.
RODGANDYSR
Compaq 2710p... | Answered on Mar 07, 2009
Mem slots are in the back pannel. Very easy to reach. SeeHP website for an easy to follow demo Video.
Compaq 2710p... | Answered on May 13, 2008
It usually already on. You just need an application that supports webcams. Try Skype or Chatroulette.
Compaq Tablets &... | Answered on Mar 24, 2011
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Compaq Tablets &... | Answered on Jan 08, 2011
if you buy tablet PC i think to the website http://www.itabletpcshop.com
Compaq Tablets &... | Answered on Oct 13, 2010
Orange means it's charging or connected vs. green means fully charged.
At least that's the way my battery charger is on my kodak camera.
Compaq Tablets &... | Answered on Jul 28, 2010
I have solved my problem vith PDA's already. Simply. I opened housing of PDA's and checked connect to screen. Thank you for intrest about to solve my problem. Hi Zdenek.
Compaq Tablets &... | Answered on Nov 04, 2009
You will need to go into....
CONTROL PANEL >> Display >> SETTINGS tab.
There you will see a pull down menu to select 1 of 2 monitors.
You have to choose to have them both on all the time (multiple monitors)
Use IDENTIFY to bring up the display # onscreen.
Please accept this answer to remove it from the work queue.
:D
Compaq Tablets &... | Answered on Jul 23, 2009
Try holding power button volume up button at the same time and when turns off resales it
Tablets &... | Answered 2 days ago
How to Enable Physical Keyboard When Laptop Switches to Tablet Mode
  1. Go to the Tablet Mode tab under Settings -> System.
  2. Toggle the "make Windows more touch friendly" option on or off.
  3. Select whether the device switches modes automatically prompts you or never switches.
Tablets &... | Answered 3 days ago
Compaq 2710p Tablet PC Logo
22 questions posted
Top Compaq Tablets & eReaders Experts
Vernon Taylor
Harrie
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Tablets & eReaders
Most Popular Question
unmountable boot volume
  • Tablets & eReaders
