20 Most Recent Hoover Steam Vac Dual V w/ SpinScrub Vacuum Questions & Answers
Hoover steam vac dual v makes humming noise and nothing else.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
1/6/2022 10:32:35 PM • Hoover Steam Vac... • Answered on Jan 06, 2022
Replace a turbine and gear assembly on a hoover F5914-900
Nine years later, and this page was a godsend! However, the price of a new turbine simply wasn't cost effective, so I opened up the turbine and found a rusted, seized bearing. Don't let the idea of fixing the turbine scare you... it's not difficult at all if you know how to use a Phillips screwdriver. And if it's not working now, you aren't going to make things worse.A bit of Internet searching will show you how to open the turbine, but even without a set of instructions, don't be afraid to take out those four screws. I was fortunate: I pulled that rusted bearing and went to Akron (Ohio) Bearing and showed them the old one. In 30 seconds the guy behind the counter handed me the identical bearing. I cleaned up all the plastic gears in the turbine, regreased them, and had it back together in no time. You don't live in Akron, Ohio?? - Just look for a bearing business in a city near you.
12/4/2019 1:08:00 AM • Hoover Steam Vac... • Answered on Dec 04, 2019
Hoover twin tank handheld steamer WH20100
Step 1 - How It WorksA garment steamer is a hand held device. Water is placed in the tank and is heated until it becomes steam. The steam is directed at pressure through a nozzle to the garment. The heat relaxes all the fibers in the garment, which eliminates the wrinkles in the clothing.Step 2 - PreparationPut cold water in the water tank of the handheld steamer. Check to ensure all the parts are properly connected. Turn the device on and allow the garment steamer to heat until steam forms.Step 3 - ShirtsPut the shirt on a hanger. You should button the collar and a couple of buttons below it. To make life as easy as possible, hang the shirt from something that will easily let you reach all around it-a shower curtain rail is ideal for this.Steam from the bottom of the shirt, moving upward. Direct the steam at the material and pay particular attention to the collar area. After you've finished, let the shirt hang for a minute before putting it in the closet. This will allow the dampness to air out.Step 4 - Dresses And SkirtsDresses and skirts can be made of many different types of fabric, with different printing, so special care is needed with these. Where the material itself is delicate, such as silk or velvet, make sure that the nozzle of the garment steamer never directly touches the material.Where clothing has been embroidered or screen-printed you should turn the item of clothing inside out and steam that side instead. That way there's no risk of damaging the print or embroidery, and the wrinkles will still disappear. When you've finished, give the clothing a minute for the dampness to fade, turn right side out and hang in the closet.Step 5 - Heavier MaterialWhere you're steaming a heavier material, you might well find that it needs several steamings before all the wrinkles go. As an alternative to this you can also use the garment steamer on the inside and the outside of the piece of clothing.Step 6 - Water LevelCheck the water level in the tank after each item of clothing. This way there will be no danger of the water running low. If you let the water run out you can end up damaging the garment steamer. On the other hand, if you put too much water in the tank, all that will come out will be water, not steam.Step 7 - Other UsesA garment steamer is surprisingly versatile. You can also use it on drapes, upholstery and even wigs. Many people pack travel size garment steamers when they go on trips.
6/26/2018 10:14:41 AM • Hoover Steam Vac... • Answered on Jun 26, 2018
0answers
2answers
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not t
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry. hoover-v-steam-vac-model-f7412-tank-obohnnchzvpzg01f0flbvqud-4-0.jpg
3/19/2015 8:06:44 PM • Hoover Steam Vac... • Answered on Mar 19, 2015
Need to remove hood on F5915905 to fix upholstery nozzle
Hello! Removing the hood is not recommended on the F5915905 as it is factory sealed and may void your warranty. We recommend taking your cleaner in to a service center for repair. Follow the link to locate the nearest service center to your location. Service Center Locator Thanks!
11/13/2014 4:10:36 PM • Hoover Steam Vac... • Answered on Nov 13, 2014
How do I switch from tools to floor on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
11/12/2014 9:20:00 PM • Hoover Steam Vac... • Answered on Nov 12, 2014
How do I switch from tools to flooe on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi Cherie! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
11/12/2014 9:19:27 PM • Hoover Steam Vac... • Answered on Nov 12, 2014
Hoover steam vac F6210 solution tank spring repair
Hi there. The spring on the clean water tank cannot be replaced. A replacement tank would be needed. Follow the link to order a replacement clean water tank for your cleaner. Search Results The clean water tank does not include the handle but your original handle will fit the replacement tank as well. Hope this was helpful!
11/12/2014 6:10:52 PM • Hoover Steam Vac... • Answered on Nov 12, 2014
How to attach part to clean steps
on the front hood there is a round port connection to open and then insert and turn to lock in the suction hose. On the side there is another connection for the solution hose. I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
10/22/2014 4:08:26 AM • Hoover Steam Vac... • Answered on Oct 22, 2014
How to clean brushes on hoover steam vac
Hi, it's Allie from Crucial Vacuum! Cleaning the brushes on your unit is crucial in maintaining your Hoover performing at it's best and it is very easy to do. First, make sure your unit is off and unplugged, and make sure to remove the clean and dirty water tanks to avoid any possible leaking. With the handle in the upright position, tilt the unit back and rest it on the floor. Grad the brush assembly and pull firmly until you remove them from the unit. Clean the brushes with running water until the water runs clear and the brushes are clean. You can purchase direct your replacement items from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you. Alejandra (Allie) Sepulveda-Rivera Crucial Vacuum Customer Care http://www.crucialvacuum.com
8/25/2014 8:08:40 PM • Hoover Steam Vac... • Answered on Aug 25, 2014
How to clean brushes on hoover steam vac?
Hi, it's Allie from Crucial Vacuum! Cleaning the brushes on your unit is a very easy and important tank to do! Your deep cleaner is equipped with removable brushes for easy cleaning. First, make sure to remove the clean water tank and recovery tank to prevent possible leaking. Tilt your unit backwards making sure the handle is in the upright position. Grab the brushes and pull firmly. You may clean the brushes with running water. Do not forget to check the brushes for any tangled hair strands or debris that can prevent the brushes from spinning properly. You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 www.crucialvacuum.com I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you. Alejandra (Allie) Sepulveda-Rivera Crucial Vacuum Customer Care http://www.crucialvacuum.com
8/22/2014 9:44:55 PM • Hoover Steam Vac... • Answered on Aug 22, 2014
The brushes on my hoover model f7412900 quit spinning.
Could be just jammed up or the turbine wheel has cracked (common problem) here is the link to buy new one. Good luck. http://www.vacpartswarehouse.com/ProductDetails.asp?ProductCode=43191018
7/23/2014 4:14:21 PM • Hoover Steam Vac... • Answered on Jul 23, 2014
Used hose to clean couches...now the water will not come out as a carpet cleaner
Turn the Tools button back to floor.
7/19/2014 2:46:11 AM • Hoover Steam Vac... • Answered on Jul 19, 2014
HOW TO mAKE BRUSHES SPIN
Check for broken belts, or belts that have been thrown off the pullys. I use the websites that sell parts to see what is inside stuff, and download the users (owners) manual and read it. Try Sears Parts Direct or the Parts Store (Google those names) for diagrams to see what belts or whatever it uses. If you can't understand the diagrams, find almost any 10-year-old. They seem to be incredibly clever, but then they have nothing else to do except try and figure stuff out.
7/6/2014 8:03:14 PM • Hoover Steam Vac... • Answered on Jul 06, 2014
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
211 questions posted
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
f7220 900 leaking but tanks dont leak
  • Vacuums
