20 Most Recent
LG MG64 VHS VCR Questions & Answers
I have just got a cctv camera it only shows up on
Some VCRs have the ability to switch the output/input of AV2 so you can record it. Look for the AV1 or AV2 on the menu of the VCR for recording options. Otherwise get one of these Scart boxes which you can find on Amazon. The buttons allow you to record and switch sources. They are not expensive.
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
It seems that the mechanism is out of mode as the
This could be caused by damage, anywhere in the mechanism. Look around for broken plastic parts first. Setting any VCR up out of sync is a nightmare, without the user manual near impossible. The mode switch will probably be out, it could even be the cause of the fault in the first place!
I got an LG VCR GC980NW (MG 64) VHS VCR. I've
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
NO SE VE
If You are not getting a video output from the LG player , get yourself a head cleaning tape ( wet type ) and run it for 15 seconds and then try playing a good tape with out any fungus on the surface.
Every time i try and rewind tapes they stop after
There could be a problem with the drive system such as a worn belt or other damage. VCR's have a mode switch which tells the electronics what position the mechanism is in. If the vcr can't perform correctly the mode switch tells the electronics to shut down. However mode switches can go wrong and give error readings to the electronics having the same effect. You need to check both the drive and mode switch.
How do you connect the vcr to the stereo
If you want to connect vcr to stereo, I assume it is for the sound feed.( to play vcr sound to amplifier) if so ,vcr should have phono socket outputs , connect them to a input on your amp , and sellect that input to play sound from vcr.
hope that makes sence
pete
I have an LG RH397D/RH399D
Hi.
Below the step-by-step procedure. When it asks Choose a Broadcasting Type, set it to ALL (digital TV and analogue). Ensure that the antenna is well connected to the socket at the back of the unit. ensure that the antenna is a digital TV aerial.
If scan goes on but there are no channel, then problem is aerial. In that case repace antenna or use a signal booster for digital TV.
Here instructions:
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
I encountered this problem on 3 different vhs of
It's perhaps MUCK my dear chap!
OK here's what to do, get yourself some Servisol Video 40. Then take of the top cover and spray the servisol in places where the tape comes into contact. Get some good quality cotton buds and wipe the same areas. Try not to disturb the grease where the guides move out to the head.
Insure the Servisol has evaporated before you put a tape in. It might be a good idea to give the head drum one last spray (without a wipe) after you have finished all the other areas.
PS if anyone smokes where the VCR is housed, you will have a lot of cleaning to do!
I have a problem with
Unplug it for a few hours, WHILE IT IS UNPLUGGED, YOU MUST PRESS AND HOLD THE POWER BUTTON FOR 5 FULL SLOW LONG SECONDS. Then wait at least half an hour more before you plug it back in.
Try 0000 as an unlock code.
Hi, I own a LG
Can you provide us a short description of your problem so that I could check on how we can assist you?
Thank you!
