20 Most Recent
Korg Legacy Collection Questions & Answers
Problem with Korg PA-50
Try to download the Operating System from http://www.korgpa.com/pa_root/en/products/pa50.html?en
Noise in the audio output for KORG PA-50 (Keyboard / Muscial)
Hello. My KORG PA50 dont give some any sound. I play but no sound come and I have test with beat I can see it works but no sounds . I think this is the problem : When you buy a keyboard you get standard sounds with the keyboard and I did something and now I dont got any standard sounds but I have my sounds I loaded in the pa50 but the problem is I THINK cause the keyboard not have standard sounds HOW CAN I FIX THIS PROBLEM ? HELP PLEASE
My Korg N364 is OUT of TUne Please help
go to global mode and find factory reset. or go to the transpose in global mode. it must be +00 or 440.000. or try to find the transpose in edit mode of the bank selected
Korg triton Touchview screen not working properly
The Korg Triton touchscreen has two main parts - The LCD screen and the touch overlay. Between the two is a type of gasket. It is really just an adhesive, but it does help keep out moisture and dust. If you were to remove the screen, you could separate the two parts, clean it and use double-face tape or glue to reattach. You can also get a replacement LCD screen, touch overlay or touch-LCD assembly from a number of places on the internet. They are not cheap, unless you purchase a generic touch overlay or LCD and retrofit.
As for repair in your area... try contacting Korg at http://www.korg.com and look for authorized repair centers.
I need the mother board
There should be service center near your house.OR better u give us your location and about cost there is range in every in product it depend on u what suites u better
Triton LE 61 : When
click this link directly to get the user manual of this product for more trouble shooting
http://www.korg.com/uploads/Support/Le_BasicGuide_633667534609260000.pdf
if its a problem due to component burn then its necessary to check the connections with continuity tester and meter to locate the burn or short in the electric components.
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
