20 Most Recent
Frigidaire GLEQ642A Electric Dryer Questions & Answers
GAS dryer will operate, but not heat. No error codes showing
If not heating at all try this. Go to electrical panel box and find the breaker labeled Dryer. It should have 2 joined together levers. Turn it off and see that the dryer is OFF (this verifies you have the right one) Operate this breaker back and forth (on and off) at least ten times. Then put it in the ON position and try dryer again. If it works you have a bad (intermittent) circuit breaker. Get an electrical handyman to change the breaker. If changing the breaker does not fix it you may need an appliance repair person. Why this is. The cycling on and off of the heat at the dryer is rough on circuit breakers. If this dryer has been in place for some years and replaced another dryer it is probable that the circuit breaker was not changed. BTW the dryer functions (except heat) operate from one side of that 2 sided breaker, while the HEAT operates from both sides at HIGH current.
Frigidaire electric dryer. 1.5 years
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
My dryer has stopped heating
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
Change from three prong to
Black and red on right and left sides of terminal block on dryer, white in the center of block, green to ground screw on dryer.
More info, let me know.
Charlie
I would like to
that is a sensor, here is website that will help,Tim:
http://www.applianceaid.com/wwf-howto.html
Fridigaire dryer GLEQ642AS2 running but not
There can be many reasons that a dryer doesn't heat up. To adequately isolate the problem you'll need to do a little electrical sleuthing.
Check the resistance of the dryer heating element, you'll need to borrow an ohm meter for that.
Verify that there is adequate ventilation for the dryer. If the dryer vent is plugged it may prevent the heating element from functioning properly.
There can also be a problem with the timer switch; if the timer isn't turning the heating element on, you won't get heat.
Drive belt is broken. How much disassemly is
usually you can remove the top panel and then on the inside you will see screws holding the front panel ...you will have to remove that.. if someone assist you they can hold tub up in place and keep it resting on back rollers while you gain access to under side of tub and route belt around tub and against tensioner to install new belt... a little time consuming but can be done by the do it yourselfer... wish you luck....
How do i change out
Remove the top of the dryer by unsrewing the two phillips head connections at the rear.
Remove the four phillips head screws located near the top at the interior of the cabinet, two on either side which will release the front door and face.
Unclip the two electrical connections at the top right to the control panel. These are preformed plastic connectors
Undo the three electrical connections from the door switch. These are individual wires with "bayonet" connections. Write down order and placement for reinstallation.
Undo the two individual wire connections for the interior drum light which are also bayonet style connections. Write down order for reinstallation.
The door and face will now be free for servicing the felts.
I have a Frigadaire Dryer
Hi
When the dryer wont turn on the issue is with the Thermal fuse which is located on the back cover panel to the exhaust duct. Before replacing it you can test continuity and check to make sure that the power is getting to the unit. Hope this help...please let me know if you require further assistance.
Daniel
Not getting hot is there a reset button inside of
gas no heat tip....
check out this
heatman101
10/17/2010 12:31:47 PM •
Frigidaire...
Answered
on Oct 17, 2010
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
