20 Most Recent
Generic Hiteker 24" Class LED-LCD 1080p 60Hz HDTV with Built-In DVD Player, Questions & Answers
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
4/24/2017 4:40:33 AM •
Generic...
Answered
on Apr 24, 2017
I bought my crystalview off ebay but it came with a password on it how do i hard reset it so i can use it
* Turn off your tablet
* Press and hold power+volDOWN+home
* It will turn on with a word start in it let go of the buttons you are holding
* Turn on the VolDown twice so a recovery mode will appear.
* Press power to restart in recovery mode
* After android image hold down power and then VolUP
* Scroll with volume button and use power to select "wipe data/factory reset"
* Then select "yes-erase all user data"
* Your tablet will now reboot
2/12/2014 11:37:45 PM •
Generic...
Answered
on Feb 12, 2014
AMT .COM
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
This is a free driver solutions.
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.Hope this helps
11/18/2012 6:48:18 PM •
Generic...
Answered
on Nov 18, 2012
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
