20 Most Recent
Dacor Millennia ETT304 Electric Cooktop Questions & Answers
Stove top in lock mode
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
How do I unlock my Dacor cooktop
When your Dacor cooktop is locked, there will be a red light lit above the Dacor emblem located under your cooktop controls.
If you see this light, pressing the Dacor emblem for three seconds will turn it off and unlock your range. Pressing it again for three seconds will again lock your range and turn the light back on.
Another fun thing about that Dacor emblem is that if one or more of your elements are lit, tapping it twice in quick succession will turn off all elements.
One of the burner controls
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure, or a touch pad sensor issue
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
Lockout light goes off by
How do I unlock the burners?
there should be a key that you have to press and hold to unlock. find it and press till the light is gone let me know how it goes
Dacor cooktop Model # SEC30-1C
is this a smooth top? glass? if so gently scrape with a razor blade yes a razor blade. then buff with cerama bryte or comparable cleaner available @ walmart or home depot etc..
