20 Most Recent
Dacor Preference SGM365SS Gas Cooktop Questions & Answers
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Hi I am trying to convert my Dacor stove/oven from
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
When front right burner is
The igniter has a switch inside the valve that you turn the gas on. The switch is not opening back up when the stove lights. You will have to replace the valve.
Gff
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Hello
We recently remodeled our ktich
I googled the problem to make sure I remembered how they worked.The only problem that would cause regulator leak is improper adjustment on a brand new one if the pressure is too high.It also talks about the spring which helps regulate the gas may lose its springiness,after several years though.There are numerous safety measures to stop the gas from coming out if you have a pilot light and it goes out which I did already know.I also know that NEVER will a regulator just simply release the gas into the air from overpressure.That would not even be allowed by anyone in the entire industry.Also,when your drawer is closed,then you open it,do you get a little whiff of gas?Natural gas(is that what you have?) does not have an odor in it's natural state.After it is drawn,a chemical is added so you can smell it and tell if there is a leak.If the odor is very minimal,it may just be the pilot burning if you have one.I would say it would likely be consistent if there was even the smallest of leaks.I used to repair gas appliances however...I was born with no sense of smell.I am including a link to you so that you can learn a little more about gas regulation.Also,I would be persistenet with your plumber and ask him to come over and do a checkup,and just tell him you are very worried about the situation since it could have obviously dangerous results,and it will give you peace of mind.They should do it for free,they better.Tell him you just want him to come over and make a quick gas reading.Hope this helps you out.If you have any questions about what you are reading,I know how all that stuff works,is designed,or whatever.
Just comment to this post and I will get an auto link.
Good luck! Greg
http://www.inspectapedia.com/plumbing/GasRegulators.htm
All gas burners have a
time to clean all the passage way of the gas specially the regulator replace it if cleaning dont work,,thanks hope this helps!
Ignitors clicking
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
