20 Most Recent Char-Broil 463232103 Grill Questions & Answers
Burner does not stay lit for infrared grill
I had a cracked Solaire infared burner and repaired the crack with Bondo. So far so good, but I don't know how long it will last
10/28/2019 5:02:52 PM • Char-Broil... • Answered on Oct 28, 2019
Grill doesn't want to heat up.....When I turn the
The hiss is from the reg when the pressure equalizes on both sides of the diaphram with the pressure coming out of the breather hole . So check the reg .
7/11/2017 2:31:43 PM • Char-Broil... • Answered on Jul 11, 2017
None of the materials I
After reviewing the Owners Manual for your grill, I see it has only 2- burners and possibly electronic ignition and an optional side burner (if you have the kicked up model). This grill is not difficult to operate, as it only has 2-burners, which translated into 2- burner knobs, which control the lighting of the burners and the flame height adjustment, once the burner(s) are lit.
But, as they say, "One picture is worth a thousand words". So I am providing a link to your model grill, that not only has the Owners Manual link, but also links on how to use, operate and cook on a gas grill. In fact, there are a couple of videos you might find of interest.
http://www.charbroil.com/ProductSupport/463270611/Quantum-Infrared-Urban-Grill.aspx
Be safe and enjoy your grill.
9/5/2011 12:36:01 AM • Char-Broil... • Answered on Sep 05, 2011
Low flame. I just filled
The problem lies partially with the tank valve and the way it was turned ON.
To solve this problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
7/11/2011 9:12:51 PM • Char-Broil... • Answered on Jul 11, 2011
How do I replace my firebox?
Actually, I don't think all the parts you'll need are still available for that model, as it has been discontinued. However, some parts like burners, ignitors, grease drain tray, etc are still available. None of the body parts are. Besides, if you could find them, the cost for all the necessary parts would cost you almost as much as a new grill. Not sure you'd really gain anything. At least with a new grill, you would have a new warranty.
Hope this helped you in some way.
5/1/2011 10:03:42 PM • Char-Broil... • Answered on May 01, 2011
Looking for Char-Broil Manual (MN463210510) I
You can find a manual you can download here.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463232103.pdf
I hope this helps.
7/2/2010 10:59:10 AM • Char-Broil... • Answered on Jul 02, 2010
Spring startup
You'll need to remove the burners and make certain there's no debis blocking the holes. Dirt, rust and spider webs are common obstruction and need to be cleared away. Also make sure gas feed tube is firmly seated to burner.
4/25/2010 5:37:54 PM • Char-Broil... • Answered on Apr 25, 2010
Burners cleaned, propane doesnt want to make
after you turn on the tank let it sit2/3 mins.before you lite it this gives the regulator time to adjust propper...thumbs up
VE6GAR73 88 99
8/10/2009 12:19:37 AM • Char-Broil... • Answered on Aug 10, 2009
Need Grill manual and parts list with pictures for for Char-Broi
Ordered part from manufacturer. Help was in the form of being able to download the assembly manual and identify the part number for the electrode (my original manual was missing). The part list for the grill listed two electrodes? and was confusing.
6/25/2009 1:41:00 PM • Char-Broil... • Answered on Jun 25, 2009
I need a manual for Char-broil gas bar-b-que Model # 463420507
Try this web site:
12/31/2008 2:09:58 AM • Char-Broil... • Answered on Dec 31, 2008
Owners Manual for Char Broil commercial Mod 463232103
If you go to the website: www.charbroil.com
and looking under customer support they offer manuals through
their.
If there is anything else I can help you with or if you are needing a part number, please let me know?
Thank you,
Fireplacegirl
4/26/2008 7:53:03 PM • Char-Broil... • Answered on Apr 26, 2008
2answers
Hello I have a Char-Broil grill model# 463268706.
You not only have to have the correct thread size, you also have to have the correct orifice size. The size of the orifice varies from grill to grill which is why "universal kits" don't work on all grills. You will have to contact the manufacturer and get the correct orifice size, or get the orifices from the manufacturer. If you need help, let me know.
8/21/2022 3:19:24 PM • Char-Broil... • Answered on Aug 21, 2022
2answers
My Charbroil grill igniter won't work. Have to
I';m sure everyone thinks they are giving good advice, but READ THE SYMPTOMS. The guy says his ignitor doesn't "click" anymore. And most of you tell him he needs a new gas regulator. Fix his problem, don't create new ones. He needs his ignitor fixed. Maybe just a new battery? Or maybe the whole ignitor unit But certainly not a new regulator, etc, etc.
9/2/2019 2:31:07 PM • Char-Broil... • Answered on Sep 02, 2019
4answers
How do you clean brass burners for a propane
A Dremel tool with a brass or steel wire brush works wonders.
12/27/2018 5:29:16 AM • Char-Broil... • Answered on Dec 27, 2018
Char-Broil 463232103 Grill Logo
Popular Tags
17 questions posted
Top Char-Broil Grilling Experts
Paul Carew
vince
ADMIN Andrew
ADMIN Andrew
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
View Most Popular
Char-Broil Grilling
  • Char-Broil Grilling
Most Popular Question
low flame just filled
  • Grilling
