20 Most Recent Onkyo RC-693M Remote Control Part 24140693 Questions & Answers
4 digit code Scientific Atlanta 8240HDC Cable box
0291,0265,02910. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
12/18/2013 11:53:07 AM • Onkyo RC-693M... • Answered on Dec 18, 2013
I need to know if the Onkyo receiver I currently have is going to work with 4k Ultra HD TV
You need to post the model number of the Onkyo so we at Fixya can look it up.
2/25/2024 6:21:04 PM • Onkyo Televison... • Answered on Feb 25, 2024
How to reset an Onkyo RC-834M remote please?
@P D Why tag to an 11 year old question? It is 2024, no one uses Universal Remotes. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote Samsung TV remote codes list 4-digit codes 4-digit codes 5-digit codes 6 more rows • Dec 7, 2023
Samsung TV universal remote codes - explained - PC Guide
2/17/2024 7:59:40 PM • Onkyo Televison... • Answered on Feb 17, 2024
Tengo un control onkyo RC 880M lo puedo programar para un reciver paramax p512
No, no es posible. Solo frecuencia ?nica ..
8/4/2023 8:38:01 PM • Onkyo Televison... • Answered on Aug 04, 2023
2answers
I have a onkyo TX-SR602 stereo and I got a replacement original rc-590m remote for it but I can figure out how to get it to pair to the receiver. I need to know how to reset it and the receiver
Hi, if you need to factory reset, there might be a small hole in your remote that you can use a pin to press into. This helps to factory reset some devices. The hole might have something like "reset" written by it. Thank you.
10/8/2022 3:06:10 AM • Onkyo Televison... • Answered on Oct 08, 2022
I have an Onkyo TX-NR545 receiver. No sound.
Make sure your on internal speakers, it can be found in menu sound options
9/25/2021 1:01:18 PM • Onkyo Televison... • Answered on Sep 25, 2021
Onkyo TX SR-605 powers off after long use/sitting plugged in but off.
This is either a weak solder connection that gets warm and looses its connection or it is a capacitor that is failing. Both require some knowledge of electronics to find and repair.
6/24/2021 2:37:07 AM • Onkyo Televison... • Answered on Jun 24, 2021
2answers
I have an Onkyo DV-CP702 DVD changer. The remote stopped working, I've tried two remotes. I imagine I'll need to replace the IR sensor in the player...any ideas?
Hello Chris, did you test if the remote cotroles emit? to test take the cell phone, put it in camera mode and point the transmitter of the remote control at the camera and press the buttons, every time you press you should see a light on the transmitter of the remote control, if you do not see it, the remote control, it does not work There would be another test to perform, only if you have an Onkio Receiver, with control output on the back panel, if you have it, you have to place a 3.5 mm Miniplug cable to the 3.5 mm Miniplug, from the DVD player to the the Receiver, this can be seen on page 19 of the user manual of your Onkyo DV-CP702 DVD, with this connection you use the remote control of the Receiver to control the DVD I hope you can solve the problem Greetings Franco Dosil Hola Chris, probo si los cotroles remotos emiten? para probar tome el celular, pongalo en modo camara y apunte el emisor del control remoto a la camara y presione los botones, cada vez que presione tendria que ver una luz en el emisor del control remoto, si no la ve, el control remoto, no funciona Habria otra prueba para realizar, solamente si usted tiene un Receiver Onkio, con salida de control en el panel posterior, si lo tiene, tiene que colocar un cable Miniplug 3,5 mm a Miniplug 3,5 mm, desde el reproductor de DVD hasta el Receiver, esto lo puede ver en la pagina 19 del manual de usuario de su Onkyo DV-CP702 DVD, con esta conexion usa el control remoto del Receiver para controlar el DVD Espero que pueda solucionar el problema Saludos Franco Dosil https://www.intl.onkyo.com/downloads/manuals/pdf/dv-cp702_manual_e.pdf
5/21/2019 1:49:04 AM • Onkyo Televison... • Answered on May 21, 2019
2answers
How do I take apart an Onkyo RC-693M remote control? I removed the four T6 screws, but can seem to get the back off..
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean. http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean].
2/7/2019 8:17:20 PM • Onkyo Televison... • Answered on Feb 07, 2019
My onkyo txnr 838 has the privacy policy on screen - it won't go off.
To check if your firmware is the latest version, go in to Setup -> Hardware Setup -> Firmware Update and check the version number. If any of the numbers differ from the latest version available, please update your unit.
8/22/2018 4:32:00 PM • Onkyo Televison... • Answered on Aug 22, 2018
Onkyo tx-sr703 reset
https://schematicscom.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrotechnician.blogspot.com/ https://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ Please visit these sites to get some details. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.
7/1/2018 4:05:40 PM • Onkyo Televison... • Answered on Jul 01, 2018
Have a Onkyo DV-CP 702 that shows loading but never goes any further or if it does then shows error of no disc or no playing, What is problem and how do we fix?
Hello, I am sorry about your issue. If you tried multiple discs and they have the same issue then the player would need to be serviced or replaced. Thank you, Onkyo USA
5/11/2017 5:05:18 PM • Onkyo Televison... • Answered on May 11, 2017
Onkyo RC-693M Remote Control Part 24140693 Logo
3 questions posted
Top Onkyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Televison & Video
Most Popular Question
4 digit code scientific atlanta 8240hdc
  • Televison & Video
