20 Most Recent
Konica Minolta bizhub PRESS C7000 Cyan Toner Cartridge Genuine Questions & Answers
Developer cyan c7000 spill
Yes you have to have the Cyan developer unit removed and have the developer changed. Once installed there are certain procedures to follow. If you don't follow the procedures you will be buying another bag of developer and start hole process over again Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Wecieved error code c-4705. Can you tll me what it is?
Code has to do with the output of the page memory to the printer is not complete.
Possible fixes: Check image control board, printer control board all four write units (The LASERS for each color total 4) I/F board or the image memory control board. That about 20,000 dollars so I would check every connection on each board then re-flash the firmware latest version. Was any body in the back of the machine doing repairs? Do you have top line surge protector not a ACE hardware 19.99 special (Nothing against Ace Hardware) GET A good one. Btw, I’m available to help over the phone in case u need at
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
Good morning, my Konica Minolta 190f says:please call service 001,what will I do to resolve this
Error code 001 is a generic service call error, and it could be related to various problems within the printer.To resolve this issue, follow these steps:
- Power Cycle: Start by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. Sometimes, a simple power cycle can clear temporary glitches.
- Check for Obstructions: Ensure that there are no paper jams or any obstructions inside the printer that may be causing the error. Clear any paper jams carefully if you find any.
- Reset Printer: Look for a reset button or a specific key combination in the printer's manual or documentation. Try resetting the printer to its default settings to see if the error clears.
