20 Most Recent Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Questions & Answers
Red light flashing i push tab on the left hand side light stop flashing ice in the maker but dont fall
If the ice has not been used for some time it becomes frozen solid, defrost it and all should be ok.
6/5/2016 4:49:24 AM • Maytag 25.6 Cu.... • Answered on Jun 05, 2016
My Maytag 2454GR side-by-side refrigerator is not
6a2cba52-efc5-4691-80a0-df6735f3f203.jpgA defective 68233-2 Defrost Timer will cause the same symptons. Sea BreezeThe Defrost Timer is part location 13 in the photo HEREanother source for the timer can be found HERE
10/10/2013 8:17:41 PM • Maytag 25.6 Cu.... • Answered on Oct 10, 2013
My freezer goes out first, then the fridge. we flip the breaker and it starts to work
my freezer starts to freeze up from moisture. ihave been unplugging it and it would work good for 2to3 months then the same thing would happen. it was unplugged this time, but it did not start back this time.
8/22/2013 2:58:52 AM • Maytag 25.6 Cu.... • Answered on Aug 22, 2013
Hi, Mike, my refrigerator fans are running, even the condenser fan at the bottom is working but there is no cooling or ice.
hi.if the fans r working then i think u should check any ice in the freezer.(clean condensing unit.well).defrost all first then try.u might be lucky or it will happen again.then u need to check/test heater and t/stat.good luck.Ali
6/28/2012 11:57:41 PM • Maytag 25.6 Cu.... • Answered on Jun 28, 2012
Is there a way to bypass the filter so the ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/24/2011 2:55:05 PM • Maytag 25.6 Cu.... • Answered on Sep 24, 2011
Water leakage. cleaned back area so fan free of
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
9/24/2011 2:26:56 PM • Maytag 25.6 Cu.... • Answered on Sep 24, 2011
Cut out keeps tripping
Hello there,
House fuse has blown or circuit breaker has tripped. you need to Check and/or replace fuse and reset circuit breaker. If the Power cut you need to Check house lights.
Hope this helps. All the best Elect_Comp
9/23/2011 12:14:22 PM • Maytag 25.6 Cu.... • Answered on Sep 23, 2011
I recently change water filter for my mds2573 side
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
9/21/2011 12:46:49 AM • Maytag 25.6 Cu.... • Answered on Sep 21, 2011
My refrigerator does'nt defrost
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
8/30/2011 7:13:08 AM • Maytag 25.6 Cu.... • Answered on Aug 30, 2011
2answers
Not cooling please advise
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/10/2011 12:36:19 AM • Maytag 25.6 Cu.... • Answered on Aug 10, 2011
Ice build up bottom of freezer compartment and
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing.By pulling the ref. from the wall there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps,
Gene
8/5/2011 6:22:21 PM • Maytag 25.6 Cu.... • Answered on Aug 05, 2011
Fridge has been leaking due to a build up of ice .
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
7/30/2011 3:35:47 PM • Maytag 25.6 Cu.... • Answered on Jul 30, 2011
Model MSD 2576VEW00 , Can
Yes, they should be able to just push them straight up flush with the door, do it as gently as you can, once it slide up about a 1/2 of an inch, they should pull straight out and off, let me know how you make out. Rick...
7/24/2011 10:46:34 PM • Maytag 25.6 Cu.... • Answered on Jul 24, 2011
0answers
The freezer side seems to be working. However, the
it could have advanced to the defrost cycle, If you can unplug it for 12 hours and not lose all your food, Try that first, with the hotter months ice slowly builds up from the repeated open and closing of the door , once the defrost can catch up it should work ok
7/10/2011 5:10:17 PM • Maytag 25.6 Cu.... • Answered on Jul 10, 2011
Water leaking from beHind bottom basket in
the defrost drain hole located behind this baskets plugged,you need to remove rear panel inside freezer and rat it out with a wire
6/30/2011 12:42:44 PM • Maytag 25.6 Cu.... • Answered on Jun 30, 2011
Maytag 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
Popular Tags
102 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
maytag 2454gr side side refrigerator not
  • Refrigerators
