20 Most Recent Xerox DocuMate 510 Document Scanner Questions & Answers
Slow then not responding
Try this link: Note: You must uninstall your current driver and OneTouch software to install an updated driver. https://www.xeroxscanners.com/en/us/products/DM510/drivers.asp#
12/27/2019 8:59:43 PM • Xerox DocuMate... • Answered on Dec 27, 2019
Documate 510 won't scan due to previous Twain?
Try this link: Note: You must uninstall your current driver and OneTouch software to install an updated driver. https://www.xeroxscanners.com/en/en/products/DM510/drivers.asp
12/27/2019 2:08:34 PM • Xerox DocuMate... • Answered on Dec 27, 2019
Xerox 510 scanner error code ll-93
you can try to power off and back on to see if this works. This can be a software issue if repowering doesn't help
7/12/2019 4:50:44 PM • Xerox DocuMate... • Answered on Jul 12, 2019
Xerox 510 error code LL7F
Here is the operator's manual that has error code listings: http://download.support.xerox.com/pub/docs/xes_510copy/userdocs/any-os/en/510dpopmana_eng.pdf
9/22/2016 6:13:59 PM • Xerox DocuMate... • Answered on Sep 22, 2016
When scanning, the image turns light blue
check paper weight
3/19/2016 10:11:04 PM • Xerox DocuMate... • Answered on Mar 19, 2016
How do you remove cartridge from xerox documate 252
no cartridge for this model
3/19/2016 9:32:51 PM • Xerox DocuMate... • Answered on Mar 19, 2016
I have a Xerox 515 documate and it is reading a internal error
try to reinstall the driver
3/19/2016 9:11:08 PM • Xerox DocuMate... • Answered on Mar 19, 2016
Can't find Xerox documate 510 driver for MAC
Sorry but no driver for MAC found on xerox website
4/4/2015 7:23:03 PM • Xerox DocuMate... • Answered on Apr 04, 2015
0answers
2answers
Xerox DocuMate 510 Scanner
www.xerox/support.com
9/28/2012 9:02:04 PM • Xerox DocuMate... • Answered on Sep 28, 2012
2answers
I went from gateway to macbook pro and would like
Have a look here
Xerox DocuMate 510
9/28/2012 7:53:11 PM • Xerox DocuMate... • Answered on Sep 28, 2012
3answers
Dont have install disc for
Here is a link to the Xerox website were you can download the appropriate drivers:
http://www.xeroxscanners.com/en/us/products/DM510/drivers.asp
I hope this helps.
Good luck!!
9/28/2012 7:48:54 PM • Xerox DocuMate... • Answered on Sep 28, 2012
Xerox documate 510 locking up on windows 7
Hello.I am a Support Engineer with Xerox Scanners. It sounds like others have given you great advice to address paper jams or locking up that you may be experiencing. If the "locking up" that you are experiencing is coming from the software, I would recommend updating to the latest available driver. I have written an article on the process that may be of use to you.If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.Regards,Xerox Scanners Support
9/27/2012 9:18:44 PM • Xerox DocuMate... • Answered on Sep 27, 2012
Assembly instructions needed
1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
  • Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    7/28/2012 7:13:46 AM • Xerox DocuMate... • Answered on Jul 28, 2012
    Xerox DocuMate 510 Document Scanner Logo
    42 questions posted
    Top Xerox Office Equipment & Supplies Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
    View Most Popular
    Documate Xerox
    • Documate Xerox
    Most Popular Question
    lost part power cord attached
    • Office Equipment & Supplies
