20 Most Recent Maytag Bravos 7.0 Cu. Ft. Electric Dryer Questions & Answers
Maytag Bravos MEDB835DC4. I replaced heating element and thermostat, also the High Limit. Removed all connections without marking and thought I would be right back at it but has been a while.
Question edited for clarity and accurate names of parts. Question moved from Cars and Trucks to Maytag Bravos. Sometimes you will find a circuit diagram in a plastic bag hidden in the machine somewhere.. They are not normally available online. The video should show you the replacement of all your parts. Pause to see the wiring. https://www.youtube.com/watch?v=RHWWTrL3VjI https://www.google.com/search?q=maytag+bravos+medb835dc4+service+manual ..
2/2/2022 11:06:46 PM • Maytag Bravos... • Answered on Feb 02, 2022
2answers
Maytag bravos dryer C0 error code
maytag bravos dryer codes error c0?
3/19/2020 4:22:17 AM • Maytag Bravos... • Answered on Mar 19, 2020
2answers
My maytag bravo dryer is
3/19/2020 4:02:39 AM • Maytag Bravos... • Answered on Mar 19, 2020
Cool down portion of normal cycle doesn't work on Bravos 500 dryer
Here is one test. Start the dryer on an air dry only cycle (no heat, air fluff) after about 30 seconds open the dryer to see if there is any heat. If so, your heating element is grounded and you will need a new heat element.
11/2/2018 5:38:14 PM • Maytag Bravos... • Answered on Nov 02, 2018
Bravo steam dryer getting hot but clothes are still damp
Hello Shawn. Glad to see you got it sorted out. Maybe you place a "how to.." tip for a wider audience. PS- while reading your added comment / update re the fix, the 'comment' block suddenly vanished as I exited from it! Not sure what happened there.. ;[ Maybe try retyping it? Regards, Clive.
12/5/2017 1:10:22 AM • Maytag Bravos... • Answered on Dec 05, 2017
Maytag bravos quite series dryer will not start
Pull the back of the dryer off and see if the thermal fuse near the dryer tumbler motor is blown.
9/5/2016 6:09:55 PM • Maytag Bravos... • Answered on Sep 05, 2016
Power is on but won't turn on
There is a safety fuse that blows and nothing will work. Check that your venting is clear and replace. If you don't know which one to replace call a technician. It's 240v you don't want to mess around.
4/6/2016 4:02:28 AM • Maytag Bravos... • Answered on Apr 06, 2016
My dryer runs its cycle of 55 minutes but instead of turning off it resets to 139 minutes and runs all that time again. Any ideas?
Type Maytag Bravos 7.0 dryer cycle problem into YouTube and see if the video comes up, thanks!
12/3/2015 6:13:22 AM • Maytag Bravos... • Answered on Dec 03, 2015
Why won't the dryer door close? Little attachment on door is rattling
Type Maytag Bravos door problem into YouTube and see if the video comes up, thanks!
12/3/2015 6:10:53 AM • Maytag Bravos... • Answered on Dec 03, 2015
Maytag Bravos XL MCT will not start, light is
If the vent output is clear and lint trap is clear, then there are a couple of more hidden spots that air can get backed up. First off, unplug the dryer before doing any of this. There's a lot of current to that plug, and getting killed is a really bad way to detect a bad wire or to identify where the heater coil inlet is.
  1. Inlet to the heater area. Laundry rooms have lint in them. All the air that gets blown out the back has to come from somewhere. make sure you don't have a clump o dust bunnies on another section of the rear panel.
  2. The blower motor itself. The lint filter can't get everything. The first time I took the back off my old Kenmore and opened up that area after the lint trap, it was like looking at a chalkboard eraser. Solid lint. The fins in the blower were packed tight with more lint. Cleaned it all out, and it ran better than it had in years.
  3. If the wall/floor connector for the vent hose goes anywhere but straight through the wall to outside, look down the hose and clear what you can, then go outside to the outlet and make sure it's not blocked, jammed, frozen shut, or what have you. Clean what you can from that end too. Hope this helps!
Good Luck!
11/10/2015 11:55:59 PM • Maytag Bravos... • Answered on Nov 10, 2015
Why won't my dryer door close? Little attachment on door seems broken 0r is rattling
Maybe the latch is in a closed position already, unlatch it and try again.
6/24/2015 12:23:07 AM • Maytag Bravos... • Answered on Jun 24, 2015
2answers
Maytag bravos dryer wont start
Hi,There can be many reasons why your dryer will not start or turn...The most common causes are the belt breaking or jumping off, or the motor going bad...Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...Dryer Repair - The Dryer is not TurningDryer Repair - The dryer will not startheatman101
5/12/2015 8:11:19 PM • Maytag Bravos... • Answered on May 12, 2015
My new dryer keeps rattling in all cycles and its level???
Annie, If your dryer is less than a year old, it is still under warranty and I would recommend calling wherever you purchased the dryer and find out how they handle warranty claims.
5/12/2015 7:35:53 PM • Maytag Bravos... • Answered on May 12, 2015
How do I disable ALL the tones on my new Maytag
She's asking "HOW DO I TURN IT OFF" retards! You are all incapable of reading!
5/12/2015 6:52:31 PM • Maytag Bravos... • Answered on May 12, 2015
All lights are on. Dryer will not start when start button is pushed. Why will the dryer not start?
Electric dryer no start does nothing Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING. NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position. If you hear a humming/clicking sound from motor area you more than likely have a bad motor. Try this test out to see if u have weak windings or relay/capacitor on motor. Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings Another thing to check is the belt safety switch. With a multi meter. Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad. https://www.youtube.com/watch?v=sTRP6kHqAFs Hey GOD IS GOOD !!!!
5/4/2015 2:28:40 AM • Maytag Bravos... • Answered on May 04, 2015
Dryer won't stop on sensor cycle
Check for clogged or kinked vent line and then after that it could be the blower wheel. But need a model to answer more precisely
3/15/2015 11:52:08 AM • Maytag Bravos... • Answered on Mar 15, 2015
Drayer repair? The dryer will not start
Test your Thermal Fuse
11/27/2014 2:13:54 PM • Maytag Bravos... • Answered on Nov 27, 2014
2answers
I have an AF code on my Maytag Bravos dryer. However, the exhaust tubing is totally clear all the way out to the outside vent and there is excellent airflow coming out of the outside vent. Also the li
I would do a Puddle test on the Lint Screen. A Puddle Test is pour a handful of water onto the Lint Screen. If it Puddles Wash it out with Dish Soap and rinse with Hot Water, See we use Fabric Softener Sheets the Oils from the Sheets clog the little tiny holes an it's hard for the air to flow thru it, This should be done every 6 Months just maybe it's giving it a False reading, also maybe check the Door Gasket
11/16/2014 3:57:05 PM • Maytag Bravos... • Answered on Nov 16, 2014
Smells like electrical inside the drum
Do you have heat in the Dryer still? If not and you have the smell the heating element probably blew a fuses due to lint build up. or the heating element itself is bad.
11/14/2014 7:15:47 PM • Maytag Bravos... • Answered on Nov 14, 2014
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
274 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
cool down portion normal cycle doesnt
  • Dryers
