20 Most Recent
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Questions & Answers
GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
GE 5 cycle automatic heavy duty dryer overheating
Hi Oxley St
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem sounds like it is a Thermostats/Thermistors malfunction.This will cause an overheat condition that you describe.You will have to locate the air tube that is going to the dryer drum. Some general area the heater is located. Is also where you will find most of them. They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.If you have continuity across the terminal it is not faulty.Be sure to check all of them. If this is not your problem then it will be the Control board if you have one on your machine.
Please take time to rate meBud
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair pagehttp://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.htmlhttp://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Not heating up
You either have a broken heating element, thermal cut-off, or fuse.
GE DBLR333GGWW gas dryer runs
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
When I went to turn
It sounds like the drum bearing is bad. It can prevent the drum from turning and overheat the motor and cause it to shut off.
Another possibility is that the belt has broken and the motor is just spininig. Some dryers have a safety that prevents the dryer from staying on it the drum is not turning.
Dryer is clicking as the
Most dryer tops come off by releasing the clips at both front corners
Slip a 2" putty knife between the top and the front about 2" in from the end and push
The clip should release then do the other side and you should be able to rock the top upwards
My ge five cycle gas
your glow rod, has failed, this is the problem 90% of the time...
you will need to call a service company
please rate/vote this response
Loud bumping sound when operating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Clicking noise
heatman101
vbmvc
My dryer makes a humming noise when I attempt to
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going
bad...
Here are a couple of tips that I wrote will help you to figure out why your
dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
