20 Most Recent
Digipower Travel Charger for Select Olympus Batteries Questions & Answers
I have olympus camera battery
three things to try.. reverse polarity on the charger (turn the plug around), clean the copper contacts on the battery and charger, get a new battery
Battery not charging
Hi
Did you try to check if the battery is working? first of all try to replace the battery with the same rating as the manufacturer suggests you.
If you have already tried replacing the batteries then maybe you are not using the charges which came with the camera. If not then use the same rating adapter to charge your camera as the amperes and voltage does matters.
7/15/2011 7:37:39 PM •
Digipower...
Answered
on Jul 15, 2011
This is a stupid question
Well, I can't find the instructions online anywhere, but the charger seems easy enough to use. The battery contacts need to come in contact with the contacts in the charger. This particular charger automatically figures out the + and - so if you insert it incorrectly, it doesn't hurt anything.
11/8/2010 9:00:40 PM •
Digipower...
Answered
on Nov 08, 2010
