20 Most Recent Sony BRAVIA SXRD HD Home Theater Projector Questions & Answers
0answers
Where can I find a
Sears should have it.
Here's a link to their site for your device.
Exploded views and part numbers
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Projector-Parts/Model-VPL-AW15/0996/0534000?pathTaken=&prst=0&shdMod=VPL-AW15
5/16/2011 8:24:14 PM • Sony BRAVIA SXRD... • Answered on May 16, 2011
0answers
A Standby green light keep blink when I turned on
lamp needs replacing
7/3/2010 5:41:15 PM • Sony BRAVIA SXRD... • Answered on Jul 03, 2010
There is a yellow hue on the right and left edges
Try a good cleaning of the unit if that does not work change the lamp.
hope this works do not shoot the helper and rate and review Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
8/16/2009 1:46:04 AM • Sony BRAVIA SXRD... • Answered on Aug 16, 2009
KDS-R50XBR1 has a yellow hue in the lower right hand corner of the screem
Hi JimmyDeps
If there is a yellow hue I would guess that this a LCD TV right ?
Which means that the blue LCD has gone and will have to be replaced.
5/13/2008 10:54:55 AM • Sony BRAVIA SXRD... • Answered on May 13, 2008
Sony VPL-DX220 3LCD Projector. How to unlock it please?
Question edited for a lot more clarity. Great Question. Press Menu Button for 10 seconds.
Data Projector
Projector Central https://www.projectorcentral.com > pdf > projecto... PDF Normal: Displays the image on the center position of the projected image without changing the resolution of the input signal or enlarging the image. VPL-DX270/ ... 54 pages
How to unlock control keys on sony projector? - Fixya
Fixya https://www.fixya.com > ... > Sony Sep 13, 2018 - To unlock the main panel keys, press the MENU button for 10 seconds. Read full answer. Aug 05, 2011 • Sony VPL-CS7 Multimedia Projector.
VPL-DX220
pro.sony https://pro.sony > ue_US > pdf > vpl-dx220 PDF Efficient, easy-to-use projector for classrooms and meeting rooms: with excellent picture quality and low ownership costs. The VPL-DX220 XGA projector is a ...
Sony VPL-DX220 3LCD Projector Specs
Projector Central https://www.projectorcentral.com > Sony-VPL-DX220 Sony VPL-DX220 Projector ; MSRP: $740 (USD) ; Resolution; 1024x768 ; Aspect Ratio; 4:3 (XGA) ; Contrast; 3,000:1 (full on/off) ; Color Processing; 8-bit. ‎Highlights · ‎Specifications · ‎Compare to Competition
3/5/2024 11:00:19 PM • Sony Office... • Answered on Mar 05, 2024
2answers
Sony vpl-es 5
How to unlock
Without remot
1/14/2024 6:05:02 AM • Sony Office... • Answered on Jan 14, 2024
Sony STR-DH800. What might be the problem with the speaker selector stuck to "ALL OFF"
Take into your local Sony Service Centre for diagnosis and replace the switch.
9/1/2023 5:27:38 AM • Sony Office... • Answered on Sep 01, 2023
Sony UP-897MD Monochrome Medical Printer. It opens anytime it is powered up.
Question edited for a lot more clarity. You just take it to your local Sony Service Centre. This is a highly specialized printer and very expensive. There is help in this link https://www.google.com/search?q=sony+up-897md+doesn%27t+print ..
8/22/2023 5:08:10 PM • Sony Office... • Answered on Aug 22, 2023
Sony (Konica Minolta) Film Drivers
I'm sorry, I'm not sure what you are asking for. Could you please provide more information or clarify your question?
3/15/2023 4:50:16 AM • Sony Office... • Answered on Mar 15, 2023
Lamp/cover button blinking red, how can I solve my Sony projector?
The blinking red lamp/cover button on your Sony projector typically indicates an issue with the lamp or the projector's internal temperature. Here are a few steps you can take to try to resolve the issue:
  1. Check the lamp cover: Make sure that the lamp cover is properly closed and secured. If the cover is not properly closed, the projector may not turn on or may turn off after a short time.
  2. Check the lamp: If the lamp cover is properly closed, the next step is to check the lamp itself. Remove the lamp and check it for any visible signs of damage, such as cracks or discoloration. If the lamp appears to be in good condition, try reseating it to ensure it is properly installed. If you have access to a replacement lamp, try installing it to see if the problem is resolved.
  3. Check the projector's air vents: Ensure that the projector's air vents are not blocked or obstructed, as this can cause the projector to overheat and shut down. Make sure that the projector is placed in a well-ventilated area.
  4. Reset the projector: Try resetting the projector by turning it off and unplugging it from the power source for several minutes. Then, plug it back in and try turning it on again.
  5. Consult the user manual: If none of the above steps solve the issue, consult the user manual for your Sony projector for further troubleshooting steps or contact Sony's customer support for further assistance.
If the issue persists, it may indicate a more serious internal problem with the projector that may require professional repair.
2/15/2023 6:36:39 AM • Sony Office... • Answered on Feb 15, 2023
I HAVE A SONY HANDICAM CARL ZEISS BUT THE SOFTWEAR DISC IS MISSING. IS IS POSSIBLE TO GET ONE?
Yes, it is possible to get a replacement software disc for your Sony Handycam with Carl Zeiss lens. You can contact Sony Support to inquire about purchasing a replacement disc, or check if the software can be downloaded from their website. Alternatively, you can also check if a third-party seller has the disc available for purchase.
2/8/2023 8:40:33 PM • Sony Office... • Answered on Feb 08, 2023
Sony projector vpl-ex145 light ok, but no lable information
If your Sony projector (model VPL-EX145) has a light that is functioning properly but is not displaying any label information, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
  1. Check the projector's connections: Make sure the projector is properly connected to the computer or device that is sending the video signal, and that the connections are secure. If the projector is not properly connected or the connections are loose, it can cause the projector to display a blank screen.
  2. Check the projector's settings: Make sure the projector's settings are properly configured for the type of video signal you are using. If the settings are not correctly configured, it can cause the projector to display a blank screen.
  3. Check the source device: Make sure the device that is sending the video signal (such as a computer or DVD player) is functioning properly and that it is properly configured. If the device is not functioning properly or is not properly configured, it can cause the projector to display a blank screen.
  4. Check for any other visible issues: Inspect the projector and its components for any visible issues that may be causing the problem. This can include debris or foreign objects that may have gotten stuck in the projector, or damage to the projector or its components.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the projector serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
12/26/2022 12:27:29 AM • Sony Office... • Answered on Dec 26, 2022
Touch screen not working for sony snaplab up-CR20l
Hi, Please turn off your device, clean the screen and power on the device before using it again. Otherwise, you might verify that you're using the device in an environment of moderate temperature. If still not working, then you might need to run a factory reset on the device. Thank you.
11/17/2022 2:07:23 AM • Sony Office... • Answered on Nov 17, 2022
Sony BRAVIA SXRD HD Home Theater Projector Logo
15 questions posted
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
yellow hue right left edges
  • Office Equipment & Supplies
