20 Most Recent
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Questions & Answers
Just had the sensor replaced on my maytag bravos
Possibly a bad circuit board for the digital read out, when you start cycle the connections on the board are room temp. after progressing thru cycle for a period of time the connections warm up and cause circuit failure for the lighted read out. However all the other functions of operation are not affected. A quick look at the board itself would most likely indicate a problem by charred or discolored solder connections.
I have a Bravo gas
remove the back,, the fan is located on the rear of the motor shaft and has reverse threads, either it is a slip on one with a clamp that has come off, or its running and you just can't tell, either way you may want to check it,, as always ,, be very careful as you do this,, don't touch anything that is connected to electrical
Dryer will not restart after
It is your motor getting hot. Try running a empty load first, then do a load. That will telling your motor is getting hot.
Have a day old Bravos
Hi you can call maytag and they will send someone out to look at it free of charge, it probably either needs leveled or they didnt remove shipping bolts. Usually brand new washer wont be broke 9 times out 10.
Sean
POWER COMES ON WHEN YOU
Unplug the machine for about 5 minutes then plug back in to reset control. If still no display, replace control.
Kelly
I have a Maytag Bravos
What is the model number of the actual unit, It may be the door seal or boot causing the problem,
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Drum is not turning
If the machine turn on and appears to heat properly, It usually happen when the belt breaks or gets out of the pulley. A more serious issue may be the motor broken.
