20 Most Recent Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Questions & Answers
Efficient, Effective Source for Electronic Manufacturing Services.
https://www.optimatech.net/pcb-ems.aspx
Kodak ESP 3... | Answered on Jun 18, 2019
You may face the "Error code-20′ with your printer installed in your Windows 7. The cause of the display of "Error code-20′ may be due to the following reasons. The desired printer may not be the default printer for your prints, issues with the USB composite device, and file missing or file corruption with the printer software supplied by your original equipment manufacturer.
Kodak ESP 3... | Answered on Jun 04, 2019
Hi , i have been using avery templates and label paper at work for ages and always printed off without problems on my lexmark . I bought a Kodak however and all of a sudden I could no longer print off my labels , when I put paper in it just came out blank and said paper wrong size .I could not find any solutions at all and was tearing my hair out . I just kept trying different things and all of a sudden I changed a setting and it worked perfectly.When you go to print your label change the ' scale to paper size ' function to A4 and then it will print.
hope this helps
Kodak ESP 3... | Answered on Mar 06, 2019
You should consult the user manual that you obtained with the printer. I suppose it would contain the best assistance on how to install the printer head. And if you do not have the user manual, you can readily get instructions online. Geeetech Me Creator 3D Printer 2 0 Free Shipping
Kodak ESP 3... | Answered on Apr 06, 2018
error 3501: STATUS_ERROR_UNIT_OPENED_WHEN_IDLE. You probably had it open when you inserted your cartridges.
Error 3502: STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY. You must have inserted some shortly after you turned the printer on for the first time so don't worry.
Error 3609: STATUS_ERROR_UNIT_OPEN_WHILE_PRINTING. This is also another basic function on the printer.
I would recommend not looking at the errors on a printer test page as they show all errors that come up on the printer, even if they are not important.
Kodak ESP 3... | Answered on Mar 28, 2018
There are many situations by witch a printer can act that way. Remove all cartridges after turning off the printer or unplugging it. On each cartridge are metal pins or contacts, usually gold colored. Take a Qtip saturated slightly with rubbing alcohol and rub (clean) off any residue, pat dry and let air dry. Do not touch with you fingers as it leaves film on the contacts. Reach inside the cartridge well and you will see corresponding contacts. Do the same as you did with the cartridges. Visually look at the contacts to see if any old ink may still be present. If so, clean again. Now you have a good connection between the cartridge and the printers contacts. Replace and see if that corrects the problem. Generally, it is a good idea to use brand new carts, but if the previous carts are full, use them anyway. When you turn the printer on, go through the head cleaning and alignment procedure first before you try and print a page. See if this fixes the problem.
Kodak ESP 3... | Answered on Jan 14, 2018
Search on internet for service manual, where you can find instruction to disassembling the printer.
Kodak ESP 3... | Answered on Jan 01, 2018
See if you can find an update online for your equipment
Kodak ESP 3... | Answered on Nov 09, 2017
Brand new ? take it back to the store ? ask for a replacement but pick a different brand ,maybe a small $ adjustment might be necessary depending if you pick a more or less expensive brand .
Kodak ESP 3... | Answered on Oct 23, 2017
Could be that your unit is running pretty much at max memory and the slightest thing or interruption will stop it dead in its tracks...Try adding another memory strip or a larger one to see if that has any effect. Or maybe your OS is unstable and the slightest thing causes a malfunction.
Kodak ESP 3... | Answered on Sep 06, 2017
Printer software may not be compatible with the OS on new laptop. Check out that angle.
Kodak ESP 3... | Answered on Aug 29, 2017
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
1,478 questions posted
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ESP Kodak
  • ESP Kodak
Most Popular Question
share kodak i2400 lan
  • Office Equipment & Supplies
