20 Most Recent
Insignia 26 in. LCD Flat-Panel HDTV Questions & Answers
Insigna 37 in screen comes on then off right away
which mean had an error detected by the main board which turn to safety mode. if you will be the one to do the repair make sure you have knowledge in electronic repair since as you know some parts with high voltage. now let first disconnect the connector that supply the inverter board for screen back light just to ensure if their is a shorted component in the board. then turn on the tv unit, if the tv unit doesn't turn off right away that was mean the cause is the inverter board.
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
How do I turn off
You mean the CLOSED CAPTION? Look for CC button on the remote.
Subtitles are usually are on DVD which you can turn it on and off under DVD menu setup.
Tv turns on then turns itself off within minutes
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty
was Expired) and found several faulty capacitors on the PSB. Its
pretty common. Major Electronic companies were sold faulty capacitors
that fail in 2-5 years instead of 10-20 due to a lack of
preservatives. It wouldn't surprise me if you have the same problem.
TV will work fine for a few years and then just fail completely or
slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
The television began losing audio off and on about
the audio problem of your TV is from the sound IC. The sound IC is faulty and it needs to be replaced for your TV sound to come up again.
Concerning the pink picture/color, how long have you been using this TV? Why I am asking is because when a TV color begins to display pink, it means the TV is reaching the end of its life span. The TV tube is going bad, that's why its showing pink.
Secondly, the pink picture is a sign that there is a problem with the CRT. This is caused by failure of the green amp transistor on the TV panel. There is a
possibility that the CRT or the transistor of the TV is bad.
I would suggest that you take the TV to a qualified repairman to help you diagnose the problem so that you would know what step to take next.
I wish you good luck.
I just got my TV and a few days later it randomly
Cover up the remote receive eye on the tv and see if it still happens. If it does it is in the set, if not there is a signal coming from somewhere else like another remote possibly a neighbor. Don't know your surroundings just trying to cover all angles
