20 Most Recent
Maytag EPICz 3.7 Cu. Ft. Questions & Answers
What does the error code Sd mean on my Maytag Epic
Hi
Thanks for using FixYa. Error 5d/Sd means too much detergent was used. Try the
following procedure---
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any
detergent.
This should clear the unit of the excess detergent. If still the problem
persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and
Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please accept
the solution if the issue is resolved post a comment for further assistance.
Thanks
Rylee
My Maytag Epic Z front load washer stops working
Hello, welcome to FixYa.
Based on your information posted I understand you have the Maytag Epic washer, correct ? The F21 error on these built by Whirlpool means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is).
This will also instruct how to unlock the unit...though once the water is gone it likely will unlock without issue, if it is at all an issue. Many times it is, but it's just a by-product of not draining correctly.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Let me know if anything isn't clear or you need further assistance, Good luck.
Regards,
Macmarkus :)
Machine stopped mid cycle, won't spin or did
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
