20 Most Recent Samsung UN39EH5003 39-Inch 1080p 60 Hz LED HDTV [UN39EH5003] Questions & Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site http://electro-medical.blogspot.com/. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Samsung... | Answered on Jan 18, 2016
Frankly, with the price TVs sell for these days, it's not worth the time to fix them, and certainly not worth the cost of taking them in for repair. I suggest just replacing it.
Samsung... | Answered on May 28, 2015
Refer its user manual.
Samsung... | Answered on Sep 23, 2013
1/4 to 1/2 inch
Samsung... | Answered on Aug 13, 2012
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Samsung LE... | Answered on Mar 11, 2015
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
Samsung LE... | Answered on Mar 04, 2015
Samsung UN39EH5003 39-Inch 1080p 60 Hz LED HDTV [UN39EH5003] Logo
12 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
installing tv mount samsung 39 led tv
  • Televison & Video
