20 Most Recent
SanDisk 2GB microSD Memory Card Questions & Answers
Recover photo
The best way to recover deleted photos from memory card is to use some memory card photo recovery software, a good one is asoftech photo recovery. You may refer to this guide
Memory card photo recovery guidehope this helps.
I can't format my memory card, the error says
go to computer direct the pointer to this pc right click and select (manage) it will take you to computer management select disc management and select the location of the drive you want format
How to Recover Audio Files from SD Card
This video shows a case where you lost audio files in SD card of camera or cell phone. In fact, data loss due to most reasons could be solved using RePicvid Free Photo Recovery, including formatted or corrupted device. Check this video and know about how to recover lost audio files from SD card.
I have purchased an micro
I had the same problem. The chip is faulty and should be replaced by the store that you purchased the chip. This is no fault on your part and by the way the chip I had was also 4 GB
My computer will not pull up pictures off my 2gb sandisk sd card.
Hi! Maybe what you're talking about is the 'Autoplay' feature of the computer. Autoplay can be disabled at some times so you cannot see it, or Autoplay only displays a view picture 'icon' when there is/are picture/s on your 2gb sandisk sd card.To manually view your pictures, you can follow this steps:1. Head on to your computer by clicking Computer on the Start Menu.2. From there you can see an sd card icon that displays your inserted 2gb sandisk sd card name.3. Click that icon, then from there you can see and browse the files on your 2gb sandisk sd card, including your pictures.Click Helpful if this fix your problem :) It would be a pleasure.Further questions? Comment below! It will be entertained. :)
Sir i have a problem.
i
SD and micro SD cards have a small slide switch on the edge of the card to protect the data stored on the card. To unlock the write protection move the slide switch to the write position.
Volume level 2gb
Open My Computer after inserting the drive into a USB port on your computer. Right-click on the drive and select Properties. You should get a nice chart with the used and free space!
