20 Most Recent
Maytag Bravos 3.8 Cu. Ft. Washer Questions & Answers
Washer keeps restarting on its own
No, definitely not normal. Cut the power to it overnight. If that doesn't fix it you either have a sticking button or a bad logic board, depending on the Maytag model.
My Maytag Bravos 300 will not power up.
Maytag Bravos 300 is a series of Washers and Dryers, but none specified. 'make model (what it is)' in all questions please. Turn the power off at the breaker for 15 minutes and that will be a type of reset on either washer or dry. Washers sometimes have button combinations to effect a reset.
Google
make (full NUMERICAL model) reset
If that doesn't work, you need a service call. having said that, the washers appear to have a known issue!
https://www.google.com/search?q=Maytag+Bravos+300+will+not+power+up
Clothes stuck inbetween basket on Maytag Bravos washer
This is for several brands ... not just the Bravos.
Based on your description, it looked like you needed to take the center agitator out first .... to then access the inner basket bolts ... remove the inner basket to then get to where the clothes are ... not a real easy task
Good luck on your troubleshooting
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
5d code not a sud issue
This code is a suds error, but can be caused by slow drain, or foreign objects in the pressure hose to the pressure sensor to detect if and when your tub is empty to spin. Fill the wash basket with warm water (hot you can), add a 1/4 cub of cooking oil to deactivate any soap within the unit, spin out and try and see if this code comes back. You have have to change the sensor to the unit to fix this issue. Good Luck I’m happy to help further over the phone at
https://www.6ya.com/expert/gere_bf68e6055dd61249
What is causing the LF code on my Kenmore Oasis?
lf is an error for long fill,you could have sediment in the water valve and you might have to change the valve but it's taking to long to fill,shut off the water to washer,remove the water lines and mark them so you know what line is cold and hot so they go back on correctly,look into the back of the water valve and see if the screens are blocked with junk from the water,also after you have the hoses off,stick them into a sink or into the washer and turn the water back on and make sure the house water valve is working ok,this is where you want to start
