20 Most Recent
Verizon Communications LG enV Cell Phone - Silver Questions & Answers
Need to block a phone num. from calling my phone
Blocking phone numbers depends on careers and phone brands, many brands come with options that can block only a certain number while some carieers can let you bar all call. Based on your request you want to block on a single number so you will need an app like black list or call manager. you did not specify you make and model but make a seach for blacklist for your model or call manager for your model.
11/14/2016 2:12:20 AM •
Verizon...
Answered
on Nov 14, 2016
I forgot my phone security code what cad I do
If you have forgotten the lock code for your Envy, no need to worry. Just remember that the default lock code is always the last four numbers of your phone number
or you can take it into a Verizon store to reset
4/7/2016 8:49:49 PM •
Verizon...
Answered
on Apr 07, 2016
How do I know when my lg 2 extravert 2 is done charging
The battery bars indicator at the top of the screen will be full and when fully charged the message will say battery fully charged, if you unplug the charger and reconnect and the battery is fully charged you will see this message!
10/18/2014 11:52:14 AM •
Verizon...
Answered
on Oct 18, 2014
Forgot lock code
The lock code can be the last 4 digits of your phone number. Some factory default codes are 0,0,0,0 1,2,3,4 Hope this helps....
4/9/2014 1:48:36 PM •
Verizon...
Answered
on Apr 09, 2014
Env unlock codes
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
10/19/2012 7:02:31 AM •
Verizon...
Answered
on Oct 19, 2012
