20 Most Recent Symantec Norton Ghost 14.0: Windows Questions & Answers
This is a fairly common problem in Windows XP, especially with SP2. The most common method that fixes it is to delete some registry keys.
Click on Start-Run, type regedit (without the quotes) Navigate to this registry path:
HKEY_CURRENT_USER --> Software --> Microsoft --> Windows --> Current Version --> Explorer --> User Shell Folders
Clear the key: Recent (right mouse click on the key/folder, choose Delete) Close the Registry Editor and restart the computer.
Symantec Norton... | Answered on Apr 15, 2011
yes it is available download the latest version of norton removal........
if the problem is same then download the perfect uninstaller ......it uninstall that software perfectly........
Symantec Norton... | Answered on Nov 18, 2010
If the hard disks are identical and they are connected to identical computers, you can use UDP cast. This can be downloaded from the Internet, free of charge.
The computers should be on a network for this.
Copy UDP Cast to CD and boot all the computers with the CD. Select the source computer as the 'Sender' and other computers as 'Receivers'.
Start to send from the source computer. Probably In an hour, all computers will have a 'ghost copy' of the source computer.
Using this method you can 'ghost' even 20 computers!
Symantec Norton... | Answered on Nov 12, 2010
Yes can Clean your Virus in your System by using the Quick Heal Total Security 2010 Trial this Cleans the Virus and Trojans Use this link to download http://www.quickheal.co.in/downloads.asp
Quick Heal Total Security 2010 - Free One Month Trial
Best of Luck
I beleive it is the 2003 version
Symantec Norton... | Answered on Jul 20, 2010
If you tried removing Ghost yourself by deleting foulder or files then it will not appear in the add/remove list. Try reinstalling it and then using removal tool. Make sure you have correct one for version and your OS. My advice is stay away from Norton products, they severely slow down performance and hinder daily activities. There are free tools online that work much better.
Symantec Norton... | Answered on Jul 13, 2010
you need to remove Norton with Nortons own removal tools. Add/remove program not the same thing as it leaves stuff in the registry. Go to norton.com and get removal tool..Run it, then try the re-install.
Symantec Norton... | Answered on Jul 07, 2010
If it's a Norton disk, call Norton, it should be bootable. If it's a disk you burned, it may not be a bootable system disk. Make sure your computer is set to boot from CD/DVD drive in the bios (setup) Press F2(usually, sometimes it's delete) while booting, go into setup, and make sure under boot devices/sequence that your disk drive is first in the boot sequence. Try the disk on another machine to see if it's the disk, or the machine. If it's the disk, Call Norton (if it's theirs) or have someone make another one for you.
Symantec Norton... | Answered on Jun 12, 2010
well the problem is that Norton normaly avoid other programs to work on your computer so it won't allow the competitor on your PC. so its upto you to go with it or to skip to alternate.
Symantec Norton... | Answered on Jan 05, 2010
This will only work if the drive with your new Windows installation is larger than the drive with your ghost image.
Assuming that the above is true, do the following:
Using disk management, create a partition on your hard drive which is large enough to accept your entire ghost backup. Restore your ghost image to this partition and then select any files or folders you may need. Once you have the necessary files you can delete the partition again if need be and use it for other storage purposes.
Let me know if you need any further assistance regarding the above.
Best wishes,
Graemevm
Symantec Norton... | Answered on Dec 21, 2009
well you can make bootable cd / dvd with utra iso
Symantec Norton... | Answered on May 29, 2009
Ghost saved the drive information in an image file.  Whatever you named your backup you would see *.gho, *001.gho, *002.gho.  That is your whole hard drive in a spanned image file.  Ghost Explorer is what you need to open and view these images and you would be able to extract files as your would from a zip file.  There are no restore points as you would think using Windows Restore.  Only the raw hard drive information as it appears on your dive now.  I'm  not sure if Ghost Explorer is provided with the home edition as I'm used to the enterprise for my work.
let me know if this helps
Symantec Norton... | Answered on Apr 30, 2009
if you wants to chat with the norton company means go to the link www.service.symantec.com
there you can get the chat option
Symantec Norton... | Answered on Mar 27, 2009
once if you connect the new hard drive means it will automatically assign it as a c: drive..(boot the computer using the new HDD but before that make sure that you have done the copymyHDD operation
Symantec Norton... | Answered on Mar 16, 2009
Warning to FixYa readers - DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
Symantec... | Answered on Nov 09, 2019
DO YOU HATE ALL THE SPAMMERS AND SPAMMING HERE ON FIXYA ??? USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! ALL TOLL FREE TOO!!
THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !!
1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-800-258-1449 1-845-764-4808
IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS AND LETS BEAT THEM AT THEIR OWN GAME.. CARRY ON4
USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! ALL TOLL FREE TOO!! THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !! 1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-800-258-1449 1-845-764-4808 IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS.. CARRY ON5
Symantec... | Answered on Nov 08, 2019
Symantec Norton Ghost 14.0: Windows Logo
19 questions posted
Top Symantec Computers & Internet Experts
Ekse
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symantec Computers & Internet
Most Popular Question
version norton ghost provides boot
  • Computers & Internet
