click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
if this fails to fix the problem
use CMDthis will differ depending on your operating system
click 'start'runtype "CMD" using xp
click start type in "CMD" press ENTER using windows 7
the type ''xcopy e:\source_folder f:\destination_folder /e /i /h'' <-- this is only an example!The /h is just in case there are hidden files. or
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
The /i creates a destination folder if there are multiple source files.after you copy files from memory stickreformat your memory stick (too refresh all the memory)then, after reformat.. goto your backup folder then copy all the files you backed up and paste to their ORIGINAL Folders! :D hope this helps
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps
this could be a driver problemclick start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download onehope it helps
click start click to open on my computer you should see your Usb drive E:
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. click start click on my computer to open you should see your drive right click then select format another way click start control panel administration tools computer management disk management right right click on your usb drive select format if you need more help with this post a reply hope this helps you
136 questions posted
149 Questions
86 Questions
73 Questions
67 Questions
28 Questions
