20 Most Recent LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Questions & Answers
6answers
Cannot remove water filter from LG 26 cu ft side-by-side in the d
Here's the only thing that worked for me in getting the water filter out of my LG refrigerator after trying for three weeks, pulling hard by hand, using high-grip gloves, and trying an oil filter wrench. You have to break or lessen the suction created by the water in the filter. Do this by first turning the filter to the Removal position (in my case, a quarter-turn to the left). Then grip the filter tight and rock it back and forth slowly as far toward the back and front of the refrigerator as possible, while keeping a bit of downward pressure on the filter. This lets the two O-Rings "walk" their way down the insert tube. After only a few pushes and pulls - voila! -- it lets go and will drop right out.
7/16/2021 8:17:14 PM • LG 26.0 Cu. Ft.... • Answered on Jul 16, 2021
Freezer not working
Replace the fan.
2/23/2014 3:36:37 AM • LG 26.0 Cu. Ft.... • Answered on Feb 23, 2014
Power off, despite changing fuse in spur
A Sounds to me your refrigerator has shorted to ground and most likely in the compressor. No there is no reset button. Can you find the correct model number? Here is a test you will need to do below=> Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, John Tripp Appliance 911 9b2619f3-e424-4e4c-9b60-c0d4e4e983fb.jpg This test works with refrigerators also.
1/31/2014 3:39:05 PM • LG 26.0 Cu. Ft.... • Answered on Jan 31, 2014
0answers
How do I get a user manual for LG 21943ST
Visit this link: manuals/mfg/lg/lsc_21943st.htmlHope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using Fixya, and have a nice day.
11/12/2011 10:46:59 PM • LG 26.0 Cu. Ft.... • Answered on Nov 12, 2011
The ice maker fills the
If you look underneath the icemaker module, you should see a reset or test button. Press it once and it should do a complete cycle. Once activated, the icemake normally continues on from there. If no action takes place when you have pressed the test button then replace the module.(a little complex to repair at component level as there are many variables ie. sensors: drive motors:limit forward and back etc.).
10/13/2011 5:37:55 PM • LG 26.0 Cu. Ft.... • Answered on Oct 13, 2011
GR-L206CVQA LCD electronic temperature control
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/22/2011 12:00:10 AM • LG 26.0 Cu. Ft.... • Answered on Sep 22, 2011
No ice is being made per icemaker after we change
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/16/2011 5:18:47 AM • LG 26.0 Cu. Ft.... • Answered on Sep 16, 2011
The water dispenser is extremely
Check/Change water filter - even if new! Also check to make sure your water supply at the wall is turned all the way to the "on" postion.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
8/29/2011 5:31:06 PM • LG 26.0 Cu. Ft.... • Answered on Aug 29, 2011
Ice maker not making ice.
Hi
There are various reasons as to why an icemaker won't make ice. A faulty water inlet valve or defrost thermostat.Please check this link to view the site to have an in-depth idea related to your issue:-
http://www.partselect.com/refrigerator+icemaker-no-ice+repair.htm
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
8/5/2011 4:50:24 AM • LG 26.0 Cu. Ft.... • Answered on Aug 05, 2011
LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Logo
69 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
cannot remove water filter from lg 26 cu
  • Refrigerators
