20 Most Recent Frigidaire 22.6 Cu. Ft. Counter Depth Side-by-Side Refrigerator - Stainless-Steel Questions & Answers
Centrigrade to farenheit
Read the manual
3/18/2015 10:03:45 PM • Frigidaire 22.6... • Answered on Mar 18, 2015
Fridge starts up when plugged in but only runs for 10 seconds then shows an E in the Freezer temp and and F in the Fridge temp. What is wrong?
Let it stand in the on position at least an hour to check it's not going through a self defrost cycle. If the temp display then doesn't change and the compressor doesn't run check you have power to the compressor and condenser fan
6/13/2012 7:33:05 PM • Frigidaire 22.6... • Answered on Jun 13, 2012
Wont get cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
9/14/2011 1:16:26 AM • Frigidaire 22.6... • Answered on Sep 14, 2011
Frigidaire Mod FRS26LF7DSB, Ice Maker
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/16/2011 3:26:36 PM • Frigidaire 22.6... • Answered on Aug 16, 2011
Ice maker wont make ice, but appears to cycle
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
8/11/2011 2:39:00 AM • Frigidaire 22.6... • Answered on Aug 11, 2011
My frigidaire refrigerator is making
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/10/2011 4:41:17 PM • Frigidaire 22.6... • Answered on Aug 10, 2011
0answers
I want to replace water dispenser in the door. I
Gently pry the cover off to access the screws and other parts of the dispenser.
12/23/2010 2:22:32 PM • Frigidaire 22.6... • Answered on Dec 23, 2010
The fridge side is not cooling now at 60 degrees.
Check to see if your evaporator fan is running on fridge side
11/1/2010 5:32:06 PM • Frigidaire 22.6... • Answered on Nov 01, 2010
Installed a new filter and pressed the reset
Sounds like you have a water valve problem
10/30/2010 7:01:11 PM • Frigidaire 22.6... • Answered on Oct 30, 2010
Ice keeps building up in bottom of freezer and on
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
10/25/2010 10:10:48 PM • Frigidaire 22.6... • Answered on Oct 25, 2010
I have a side by side fridge that quit cooling
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/16/2010 7:28:35 PM • Frigidaire 22.6... • Answered on Aug 16, 2010
Refrigerator not cooling
if your talking about the damper vent door motor,it is behind the vent grille where the damper vent is and is controlled by the refrigerator temp adjustment control,sometimes these doors freeze open or shut from condensation,if this is the case take a hand held hair dryer and thaw and dry out door and hinges and then try adjusting temp asnd see if the door opens and closes now
4/19/2010 12:59:53 PM • Frigidaire 22.6... • Answered on Apr 19, 2010
How do I get it level on the floor?
on the bottom of the fridgerator there is small feet that screw up and down to ajust on the frunt and rear it uses a 1/2 wrenh or 9/16 inch wrench to raise or lower the feet. however the door screws on top and bottom could be loos as well.
4/14/2010 4:17:49 PM • Frigidaire 22.6... • Answered on Apr 14, 2010
Frigidaire 22.6 Cu. Ft. Counter Depth Side-by-Side Refrigerator - Stainless-Steel Logo
Popular Tags
29 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire mod frs26lf7dsb ice maker
  • Refrigerators
