20 Most Recent
Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED AF-S DX Zoom Lens for DX SLR Cameras Questions & Answers
My 55-200mm lens won't focus.
if other auto-focus lenses work, then it is likely that this particular lens has a defect I suggest you send it in to Nikon for servicing
11/25/2017 1:47:42 AM •
Nikon...
Answered
on Nov 25, 2017
My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
5/26/2015 8:43:00 PM •
Nikon...
Answered
on May 26, 2015
Clean inside lens fungus
If you realy have fungus in your zoom lens, you can't do anything. If it does not show on the pictures, just keep the lens dry. (use silica gel) If you want it it be repaired, it will cost more than an new lens.
12/2/2014 8:38:00 AM •
Nikon...
Answered
on Dec 02, 2014
Whatever you do, do not open the lens. You will never be able to reassemble it. If the fungus is adversely affecting your images, you need to take it to a qualified camera repair man or send it to a Nikon repair depot found on the Nikon website. If it is not affecting your pictures, I would just live with it.
6/18/2014 12:39:59 AM •
Nikon...
Answered
on Jun 18, 2014
Squeaking when try to focus. will not focus
My lens is also doing that same thing... and I just posted pretty much the exact thing you said...Mine squeaks and goes in and out really fast.. I do know that you can put the camera on manual mode and focus manually on mine, but would like to have the auto focus sometimes too. If I dont get an answer soon, I may send it in... I believe its a motor problem in the lens....
11/26/2011 6:25:39 PM •
Nikon...
Answered
on Nov 26, 2011
Not focusing
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
4/6/2010 3:34:49 AM •
Nikon...
Answered
on Apr 06, 2010
Nikon 55-200 is locked on 55 and won't extend to
Assuming that you've already tried a good firm hand on the zoom ring then all you can realistically try is to give the lens a few good firm slaps onto a desk to try and free up whatever has gone wrong. Brute force usually sorts them out, but it is "kill or cure". This lens lacks a macro mode, so this is not the usual simple case of adjusting a lens control and then slapping your forehead with embarrassment...
The lens is otherwise uneconomic to repair as it's one of the cheaply built kit lenses and so you can easily obtain another for less than the cost of repairs.
1/30/2010 7:47:37 PM •
Nikon...
Answered
on Jan 30, 2010
Is is worth fixing?
infopgdesign,
That's a close call, depending on how bad the housing is broken, there may be lens alignment issues, the adapter ring or the housing body may be cracked, take it in to a shop so they can look it over closely to help you decide if you should send it to Nikon for repair which depending on the severity of the damage will determine the cost. if it's close to what you paid for the lens, save your money and buy a replacement, maybe the VR version of that lens if it wasn't.
randy320sgi
1/18/2009 5:59:57 AM •
Nikon...
Answered
on Jan 18, 2009
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
12/31/2008 5:09:12 PM •
Nikon...
Answered
on Dec 31, 2008
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.
FULL 'make model (what it is)' in all questions please first 3 words.
Google
Nikon (model) manual
Read it it LEAST 3 times. Use the camera every day for a week and read it again.
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full.
r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining.
If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
Error clock R49 error on Nikon D80
this error message is usually caused by a low battery. Here are some steps you can try to fix the issue:
Remove the battery from your camera.
Fully charge the battery using the Nikon D80 battery charger.
Remove the memory card and reset the camera by using the reset option in the menu or by pressing the reset switch on the camera's body, under the connector cover .
If the error persists, Nikon recommends waiting for one or two days before sending the camera in for inspection
How do I fix the err low f4.8 on my Nikon d80
From the sites I've looked at al say this about f....
Most of the time, this
F Error message is limited to Nikon DLSR cameras. This particular
error message appears when the camera is not able to communicate with the lens.
To
fix F- error message, clean the contacts on the rear of the lens with the help of microfiber cloth and make sure that the lens is locked into its place.
If the problem still persists, then try different lenses to identify whether the problem is in the lens or camera. If you are not able to fix it by yourself, then you can take your camera to the service center.
I'm not a camera buff but I thought I'd pass this on.
other sites too....
https://duckduckgo.com/?q=err+low+f4.8+on+Nikon+d80&t=ffab&atb=v159-1&ia=web
Best to you.
