20 Most Recent
Pinnacle Dazzle DVD Recorder Questions & Answers
No Picture
You need a 'Y' splitter for the video to split between the TV and the Dazzle box.
Audio
use windows taskmaster, select process, find dazzle, right click, select priority, real time.
There is a small black outline going around my whole video screen.
I had the same problem but I had and still get a red line at the bottom of the screen. Best thing to do it crop it out or just add Pictue in Picture Video effect then set it to full screen then set the width and height so it can crop out it self...hope this helps
If i get a dazzle dvd recorder, will it work on
Hi and welcome to Fixyah,
Yes it will work with Windows 7, The only problem that you encounter is if the driver of your device is not detected. Remember that the disc of Instant DVD recorder work with 32 bit only and not the 64 bit.
But no worry there is available driver for 64 bit if your Windows 7 is a 64bit.
I have dazzle DVC 170
one of the drivers is not compatible or unstable with you system. make sure you have the relevant firmware on your system, update the drivers from the driver menu that is in device manager win 10 its right click on windows logo (start) bottom left and click on the driver and update before using it if no update is available you could try the properties of the software. right click on the icon for the software and menu will pop up go to properties click on that and then go to menu compatibility and click to run on win xp mode or another mode. then press ok.
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
