20 Most Recent
Nintendo DS Lite Questions & Answers
Freezing up
that happens to mine sometimes i smash it against the wall and it works its so cool
Error code 52100
Hi there! There are a couple options you could try to solve this problem!
To solve this error :
I would first check Nintendo's special notes router infomation page located
here.
- If
you can't locate your router on Nintendo's special notes router
information page, log into your router and change the basic rate to 1-2
and the transmission rate to 2. Try to connect again.
- You can
try to manually assign an IP address to the Nintendo DS as another
device may be sharing the same IP address of the Nintendo DS.
- To
manually assign an IP address to the Nintendo DS, on a PC click Start
> Run > type CMD and press Enter > type IPCONFIG/ALL and press
Enter. On Windows Vista, click Start > type CMD in the Start Search
box > click on CMD icon > type IPCONFIG/ALL and press Enter. The
IP address for the Nintendo DS must be 10 digits higher than your PC,
for example 192.168.1.200 becomes 192.168.1.210. Also make sure that the correct DNS is the entered under the DS manual settings.
Hopefully one of these options is your answer and you can easily fix your problem! Good luck! If you need any further assistance I would suggest calling Nintendo at 1-800-255-3700.
How do i get downloaded games onto R4 card?
you dont say if you have the r4 softwear loaded on the sd card if not try the r4 website and download the correct softwear for your card,you should then be able to open the games you have downloaded,hope this helps
How do i unlock parental control, if i forgot my
Go into the settings menu, Parental controls, reset parental
controls. Click through the confirmation screens, and then it will give
you a confirmation code and ask you to call Nintendo.
Instead of calling Nintendo, go to
this form
and enter the code. Even though it was originally written for the Wii,
marcan's reset code generator will give you a valid code that you can
enter into your DSi to remove the parental control.
Keeps saying theres no disc card inserted when there is
When it says there is no card, the logic board can't read a card. So perhaps you used a defective card, or contacts are dirty or bent, or when it says so with more than one card, the device can have a defect, like a connection lost or as I said defective logic board.
How to play music and movie on my nds lite.
In order to get movies for your Nintendo DS, you must first purchase a kit which includes: USB cord with a microSD card slot, a 512 MB memory card, and an adaptor that fits into the DS cartridge slot. This hardware package is available from DSvision for only about $37, and it will be available in 2008.
Once you have the hardware package, you can begin downloading movies at the DSvision website from your computer, and then transferring those movies to your DS with the hardware. One downfall is that you can't download movies using the DS Lite's Wi-Fi capabilities, although this may be something to look for in the future from Nintendo and DSvision.
Upon launch, there will only be about 300 movie titles available for download, but they hope to increase that number to 10,000 within two years. You will also be able to download TV shows and e-books as well.
The cartage is bigger than a sd card
Get some isopropyl alcohol and with a cotton swab clean the gold fingers on the cartridge. As long as they fit in the slot this should solve your problem. Best of luck to you.
DS Lite Slot -1, games cartridge not reading games repair / resolution.
Has your slot -1 games cartridge reader stopped working? Is it being temperamental with your cartridges? Here are a few tips to get your DS lite back to full working order.
1) First try giving the games cartridges metal contacts a clean, ideally with a cotton bud and white spirit (if you don't have white spirit try avoiding anything soapy, if you can try to stick to an alcohol based solvant such as nail polish remover).
2) If that doesn't work you can try cleaning the cartridge socket (slot1), you can buy proper cleaning cartridges for the DS lite, or, if your feeling brave you can get a jaye cloth, dampen it with an alcohol based solution (same as what is used to clean the cartridge) make sure it is well wrung out so that the cloth is only slightly damp and thinly wrap it around a rigid ruler, which can then be gently placed into the slot to give it a bit of a clean.
3) If both of those fail you may find that some of the pins within slot1 are bent/snapped and so this will need to be fixed, If under warranty i'd suggest taking them in to get looked at. If they are not and you feel brave you can set about fixing it yourself, take the DS lite apart and have a look at the pins on the slot1 socket, if they are damaged you can buy a replacement socket on ebay, but be warned it is a tricky job to solder a new one on.
To solder the replacement slot -1 on firstly you will need to remove the old one, take care not to damage the pcb tracks when doing this as it will cause the replacemet process to be far more difficult and a purchase of a track repair fluid may be needed. Your best option is to de-solder it buy removing the exisiting solder to free it from the motherboard. Once you have done this you need to put the new one on, take great care not to fuse any of the pin connections together with the solder as this will cause the DS great problems and break it. Re assemble the DS lite and give it a try.
If you need help with taking the DS lite apart please refer to my other tips and tricks posted on here.
Just so you know I take no responsability for any damage that may occur whilst following these tips.
Regards,
SOD69
Marvel lego cheat codes
Cheat mode :Pause the game, select the "Extras" option, and choose the "Enter Code" selection. Then, enter one of the following codes to activate the corresponding cheat function:
Result
Code
Extras
2x Stud Multiplier
UZFBG4
Minikit Detector
7VKCT2
Vehicles
Avenging Cycle
5T3CQU
Pumpkin Chopper
35E41W
SHIELD Staff Car
D5B7O3
Spider Bike
SH9MZQ
Characters
Beetle
Black Cat
P9OWL0
Captain America (Classic)
7HWU4L
Carnage
AA0Z50
Howard The Duck
J58RSS
Hydra Soldier
B7AA3K
Iron Man (Mark 17 - "Heart Breaker")
2NGSRZ
Iron Man (Mark 38 - "Hulkbuster")
CK7SDS
Iron Patriot
MODOK
SZ8Q06
Spider-Man (Future Foundation)
WFOZXQ
Thor (Classic)
H8CSE6
War Machine
TQ4C57
Wolverine (with hood "cowl")
OAW2LB
