20 Most Recent
Casio Portable Keyboard Touch Sensitive Keys Questions & Answers
Casio PX700 sensors not working
Hi. I don't have a 700, but on the other privia's I have seen, there is a function key combo to turn on and off the touch response. Go to casio, and download the manual. You hit "fn" and then one of the lower keys. There are 4 levels of sensitivity on my machine. -Don
Casio FX-880P and TM Error
You need to reset you calculator. With the casio fx 880P on, press "P" in the back until the display goes off, then press all reset, next to the Power On. If it doesn't work, try again.
It worked with me. Daniel.
Keyboard rattle
No. You need parts. Best to get it serviced by CASIO authorized repairer.
A key has popped up
Could you please Confirm, the key that is Popped out is Broken or not? How it is Popped out?
Let me know, so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Casiotone CT310 electronic organ, need
I too have checked the net for a manual for your Casio Organ. I checked the Casio website, they offer some of the manuals on their website. However your model was not on their list.
Click
here to send a request for the manual from Casio. Send them an e-mail they will be able to either show you where it is for download or they will send a copy to your home via post.
Take care!
damnor01
I know it's old but I have a casiotone ct-310 that
i dont know if this helps but the polarity of the power source going in to the keyboard may have an affect on it, i have one of these keyboards myself and on the back of the keyboard there is a schematic on how the polarity of the power source should be
I have purchased a CASIO CTK 700 keyboard, but I
there are many software applications for your computer available out there my advice is to find one and use it all the time as i learnt when i started playing as with any other instrument the only way you will learn is to practise, practise, practice any keep trying it no matter how many times you fail
The volume control on my casio px-120 does not
ok your volume control has bit/dust in it you need to strip it down as best you can and spray wd-40 into the control this will release all the grit in the control knob (trim pot) and should work fine then..
Casio PX-120 Dead Key
Taking It Apart Can Void The Warranty. I Suggest Taking It In.
(Don't Tell Them You Had It Apart!!!)
I went to play it the other day and i plugged the
Sounds like either the power cord is loose either in the keyboard jack or in the wall socket. If the keyboard has an internal battery too, remove it, press power button and hold it for 5 long seconds, put battery back in, plug it back in and see if it resets itself. If not, the power supply is likely bad.
Ctk-601 sustain pedal issue. I am trying to use a
If the pedal is a simple switch, and not a MIDI device, then most probably the only difference is that in one pedal the switch is wired so it is normally open, and in the other normally closed.
Modifying that would involve disassembling the pedal and looking if the switch can be rewired the opposite way.
Casio Privia Px-120 88 key digital piano frozed.
Not sure that this is the right answer.
But it works very well with other electrinic devices.
When you turn off the unit it resets itself.
ie: the parser code program on the IC (Integreated Chip) defaults to the base program
upon power up.
This problem commonly occurs from a voltage drop at a standard household outlet.
It can occur from other high draw electrical items that are on the same circuit being turned
on while your playing your keyboard.
So stay away from extension cords as these increase electrical resistance.
ie: you dont get enough power for the device.
Another thing that can cause this is power strips.
I know we all use these for certain items but they can wreak havok on electronic
components by not being able to supply enough power.
Best that if something like this happens to plug the item directly into an outlet.
And make sure that Momma's microwave isn't gonna kick in anytime soon.
Hope this info helps.
Bobby
Keys on Casio keyboard pulled up
I have a Casio CT-648, which looks like a smaller version of yours. I had the same problem, and got brave and opened it up. I took off the back, which takes several screws. Once it was opened up, I saw the keyboard was fastened to the frame in sections of keys. I unscrewed the section with the raised key (I believe it was 5 screws), slid the key section toward the front of the keyboard, and was able to get the slides to re-engage with the tab below it. I now have a smooth keyboard.
Casio px 410 r does not work
If you are familiar or would feel comfortable opening up the unit and trying to find the problem respond however if you do not have experience or are not comfortable with opening up electronic devices i would suggest you go to the link below.
https://www.ecasiorepair.com/
Hola, me obsequiaron un casio paw1300 3070, la carga esta al maximo y puedo ver hora y fecha, pero las funciones no dan lecturas, altitud, etc, tampoco funciona la luz, cual sera el problema?
English translation;
Hello, they gave me a casio paw1300 3070, the charge is at maximum and I can see the time and date, but the functions do not give readings, altitude, etc., the light does not work either, what would be the problem?
Casio paw1300 3070 Problems
Wie kann ich die Casio TK 2300 umschalten auf Einzelbon
Um die Casio TK-2300 auf den Einzelbon-Modus umzuschalten, befolgen Sie bitte die folgenden Schritte:
- Dr?cken Sie die Taste "Programmierung", um das Programmierungs-Men? aufzurufen.
- Geben Sie das Passwort ein. Standardm??ig ist das Passwort "0000", es sei denn, es wurde zuvor ge?ndert.
- Dr?cken Sie die Taste "1" f?r den Registrierungsmodus.
- Dr?cken Sie die Taste "3" f?r die Bon-Einstellungen.
- Dr?cken Sie die Taste "1" f?r die Einzelbon-Einstellungen.
- W?hlen Sie "Einzelbon" aus, indem Sie die Taste "1" dr?cken.
- Dr?cken Sie die Taste "CA/AT/NS" (Clear All/All Tender/No Sale), um das Programmierungs-Men? zu verlassen.
Ihre Casio TK-2300 ist nun auf den Einzelbon-Modus umgestellt. Wenn Sie einen Artikel auf den Bon legen, wird ein Bon ausgedruckt, der nur diesen einen Artikel enth?lt. Wenn Sie weitere Artikel hinzuf?gen m?chten, wiederholen Sie den Vorgang.
Ich hoffe, das hilft Ihnen weiter!
