20 Most Recent
Insignia DVD Player with MP3 Playback/JPEG Viewer Questions & Answers
Insignia DVD player NOT WORKING
Hey jgconstable,
Before seeking repair assistance, there are a couple of options that you may wish to try out at home.
First, you may want to try cleaning any affected discs if you are only encountering this problem with a select few titles. Any kind of contaminant (dirt or lint) can often cause optical devices to not recognize a media title that is inserted. I would suggest checking each disc that is affected for any signs of scratches, and try cleaning them with a soft, lint-free (typically microfiber) cloth. Remember to use gentle, outward strokes from the center of the disc towards the outer edge.
Second, you may want to try cleaning the lens of the player itself. Many retailers (including your local Best Buy™ store) often sell commercial cleaning kits that are designed to be inserted directly into the player, in place of a normal CD or DVD.
If cleaning doesn't resolve the problem, you may wish to attempt resetting the player. Many DVD players will have either a physical reset button located someplace on the exterior casing, or be capable of a "soft reset." A soft reset is typically done by pressing and holding the power button for five to ten seconds, but please keep in mind that your owner's manual would have the most detailed information on how to reset the player to the original factory settings.
Should the player continue you malfunction, remember that you can always bring your DVD player into your local Best Buy™ store for service and repairs.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
My dvd player only plays movies in black and
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow. If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Unknown disk
hello,
when the disc player shows unknown disc error, it simply implies that the lens of the player is weak and cannot read the disc.
the solution is for you to try to clean the lens with a lens cleaner or better still replace the lens.
take care
Need code for remote
You didn't specify wheather it was a 3/ 4 digit codes you needed so i posted both.
3 digit codes.
405,
456
4digit codes
1401
1070
1066
0456
0921
0430
0905
0907
0405
1406
1407
1408
1413
Hughie.
How to use parental control
You can enable customize Parental Controls via your TV's on screen menu. If you have previously set a password, you will need to re-enter your password to begin. If you have forgotten your password, try 0000 (four zeros) or 3448 (the default password may vary by TV model, so consult your User Manual for details). You can find detailed instructions for using the parental controls in your TV User Manual, available for download at
InsigniaProducts.com. Just search for your TV model number and click on the Support/Download tab. I hope this helps.
6/18/2023 7:04:11 AM •
Insignia...
Answered
on Jun 18, 2023
