20 Most Recent
Webroot Spy Sweeper with AntiVirus: Windows Questions & Answers
I need a key code to register my free scan spy
With some applications the publisher only wants the user to register using the free copy. tried contacting the publisher via their website or your application should have a registration link which will take you straight to the website
After installing webroot comp applications does not work
There might be a conflictBackground b> Many personal computers connected to the Internet will more than likely eventually become infected with spyware, malware, viruses or Trojan horses. Such programs spread via spam, bad links or freeware. Once they invade your computer, they can do anything they want, such as disabling your antivirus software, tracking your keystrokes and deleting files. b> About McAfee and Webroot b> McAfee and Webroot are some of the most popular computer security programs. Both companies have features on their programs, such as firewalls and live scans, which prevent future infections. Computer owners, however, should never run two programs since they cause each other to crash. Only one antivirus program should be on a computer at once. b> Spyware Prevention b> Along with using computer security programs, computer owners can prevent infections by browsing the Internet with caution. They should avoid file sharing and ad-laden websites since such websites often harbor spyware. They should also avoid downloading anything without researching it beforehand use as safe a Web browser as possible. If you right click in the bottom toolbar select task manager under processes and the applications tabs you will see what is running and ticking over if you see something running that should not be select end now or even uninstall it or disable it Hope this helps
I'm getting an error from
Webroot:
This solution addresses Spy Sweeper 6.1 and Webroot 2011 (version 7.0) The Webroot Client Service must be running on your computer in order for Webroot software updates to function. If your updates are failing, follow the steps below to make sure the Client Service is started on your computer.
- Follow the instructions for your operating system.For Windows XP:
- Click the Start button, then click Run. The Run box opens.
- In the Run box type services.msc and press OK. The Services window opens.
For Windows Vista or 7:
- Click or the Start button.
- Type services.msc in the Start Search box and press the enter key. The Services window opens.
- In the Services window, scroll down and locate Webroot Client Service.
- Right-click on the entry for Webroot Client Service and choose Properties from the menu that appears. The Properties box for the service will open.
- In this window, locate the Startup type. If it is set to Disabled, use the drop-down menu to change the setting to Automatic and click OK.
- Close the Services window.
Won't not loading... please wait
If it is alaptop Do a power drain and try booting the computer..
Procedure to do power drain..
*disconnect all the external peripherals connected to the computer
* remove the battery and the power cord from the computer
* press and hold the power button for 30 seconds
* now reseat the battery and power cord and switch on the computer
Thank you
Webroot spy sweeper with antivirus
It sounds like your Webroot Spysweeper With AntiVirus Program crashed.
1. Click on CTRL+ALT+ DEL keys (All at once) to bring up the task manager.
2. Under the Applications tab>Click on webroot spysweeper to highlight it. Then click on end task.
3. I would suggest you uninstall and re-install it.
4. Go to Start>Control Panel>Programs>Uninstall a Program
5. Scroll down thru all Programs until you find WebRoot Spysweeper. Click it to highlight it- then click uninstall.
6. When it is finished uninstalling-click on Start>Restart pc.
7. After you log in to your pc>re-install webroot spysweeper.
8. After installation is complete, reboot your pc. This should fix the problem.
I right click on the
I used to work with spy sweeper very often at my old job and I ran into this every now and again. Generally Spy Sweeper would need to be re-installed, or installed over to fix this. I recommend going to their website, and downloading the most recent version of the software. You should then be able to install the software, and it should turn your spy sweeper off and write over the bad files. If this doesn't fix your issue, I would recommend uninstalling your current version of SS w/AV and then once again installing from the website.
Have a nootbook how i
Most software comes with a one-use license.
This means that you will need to purchase an additional license for every pc which you wish to have it installed to.
If you have done away with your old pc, and only want it on your new pc, you can call webroot, and have them de-activate the previous installation, and that way it will be cleared for installation onto your new pc.
If it is a multiple license disc, (it would say so on the packaging) then you should be good to run the installation from disc on up to three different computers.
If there are problems with registration, you are pretty much locked into calling webroot for assistance.
Cheers!
OK SO MY MOM BOUGHT THE PRODUCT AND SHARED IT WITH
Go to a better anti-virus program that is free. Go to www.filehippo.com and dowload Avast. When you install it you can register it as a free version for a year and then re-register it as a free version next year. Avast works very well with the Windows Firewall and it is easily the best anti-virus out there.
These days, you must have a good security system on your PC; get Avast or whatever else you like at
FileHippo, but do not delay. Tell you Mom about Avast *** well; it is better than Webroot in my opinion.
I have webroot antivirus and spysweeper on this
He is learning the hard way!!
Install "malwarebytes" free from the internet (Best free anti-spyware on the net) / install / update / full scan / remove everything that shows.
My strong advice is to PAY for an anti-virus program as they are far superior to free ones.
Rphelper.exe keeps popping up When I hit block it
Erase the software in its entirety and reinstall it again
If this problem persists, you may need to clean out your pc of any software corruption ( I recomend downloading Tune-up utilites) and scan your computer for viruses and malicious software (going to Kapersky.com and download Internet Security and run it)
This should remove all software issues if the initial reinstallation of Spysweeper doesnt work
I hope this helps
