20 Most Recent
Microsoft LifeChat Stereo Headset with Noise-Canceling Microphone Questions & Answers
My microsoft lifechat LX-2000 headphones
1) Place the Mouse pointer on the speaker icon and right click the Mouse.
2) Select recording devices / Properties
3) Next click on Levels and set at 50%
4) Select Configure / Setup Microphone 2nd on list
5) Click OK
1/8/2018 8:35:17 PM •
Microsoft...
Answered
on Jan 08, 2018
Annoying noise + low volume
the wires are shorting internaly, if they are a cheap pair of headphones throw them and buy some more, see if you can borrow another pair to double check but i am pretty sure this is what it would be. cheap headphones dont last very long as they are mass produced junk, please leave feedback
4/7/2010 8:52:17 PM •
Microsoft...
Answered
on Apr 07, 2010
Dont now how how to use them
my head phone is working but my microphone does not, there are two cord one is red and other black, when i plug black its fine for head phone tell about red cord
7/3/2009 2:52:58 AM •
Microsoft...
Answered
on Jul 03, 2009
Used to have this
a microphone and a speaker work off the same principles. there is a magnet and a coil.
when you speak,the air makes the speaker cone move and the coil produces a signal because it is moving across a magnetic field.
when you apply a alternating voltage to the coil,it moves in opposite direction to the magnet because likes repel and opposites attract.
if you apply dc to a speaker it will stay in or out depending on polarity.a bass guitars lowest not is about 50hz or cycles per second.the signal is going plus minus 50 times per second and that is why a speaker moves.because of the size of large cones,they can not move so fast,that is why woofers are big to move lots of air,and tweeters are 1 inch or so,because the range is 20khz or 20000 cycles per second.beacuse microphones have to be very sensitive,the voice coil and structure are extremely small and light.a microphone will produce sound with a signal applied,but burn out with very little power.even a clock radio will blow it out.
6/12/2009 4:52:07 AM •
Microsoft...
Answered
on Jun 12, 2009
My mic is recording sound from the headphones, NOT the mic piece, why is this?
-right click on the volume icon on the system tray and select recording devices
-there should be a selection that says stereo mix or something like it
if not.. right click on a blank space on that box and select "show hidden devices"
-you must disable this device
-make sure your microphone jack is enabled
-click apply and it should work
4/12/2009 6:38:31 PM •
Microsoft...
Answered
on Apr 12, 2009
How can i regain audio when not using headset.
no the software doesnt block the speaker signal. you will need to go into your sound applet on control panel and designate which ports the speakers are plugged into and which the headset is plugged into. very easy set up and at least in windows xp it even prompts you if your plugged into the wrong port it will tell you the right one to change them to.
4/1/2009 3:09:48 AM •
Microsoft...
Answered
on Apr 01, 2009
Hi, I am looking for
I absolutely loved my Lifechat LX-3000 from Microsoft. very clear sound and the microphone didnt destort my voice when I DJ online.
4/1/2009 3:05:12 AM •
Microsoft...
Answered
on Apr 01, 2009
Microsoft lifechat 3000
I get the same problem, and i go to the microsoft website to download the software needed and it wont even let me do that....
Whats the go..
3/21/2009 8:16:38 PM •
Microsoft...
Answered
on Mar 21, 2009
Crackly Headset
Mate, im having the same Problem i have no idea what to do!
When the Red light is on, it doesnt crackle, but when the Red light is on.. i cant use it as a Microphone.
But when i turn the red Light off.. there seems to be a crackly noise everytime i speak!!
I did manage to fix it for like a day.. i just pushed all the wires and it seemed to work. but hasnt for over a month now..
2/15/2009 1:14:53 PM •
Microsoft...
Answered
on Feb 15, 2009
Microsoft LifeChat Microphone Headset Doesn't Work Properly
You should take your headset to another computer/location and see if your problem still exists.
That way you can eliminate problems with either your computer hardware or your outgoing internet connection (jitter).
I don't think that the CD will be necessary, since it is a USB device, which contains it's own little sound card and doesn't need any drivers.
If the problem persists and it turns out to be a problem with the headset, I would definitely return/exchange it.
12/20/2008 8:46:46 PM •
Microsoft...
Answered
on Dec 20, 2008
