20 Most Recent
Kingston 2GB Secure Digital Memory Card Questions & Answers
Kingston SD Adapter card 4GB
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwir58qry6ODAxW2g4kEHXT_C3MQrAIoAHoECB0QAQ&url=https%3A%2F%2Fwww.quora.com%2FHow-do-I-fix-my-micro-SD-card-that-became-a-read-only-memory-card&usg=AOvVaw2Bw_FlaJGL3PQWr3k-N8MS&opi=89978449
Im using micro sd 2gb
I have seen this many times, most of the time it's because the index file was writing or cleaning itself when you removed it. This is what the "EJECT" is when you right click. As a matter of course, you should always 'eject' the media before removing it. (It doesn't physically pop the media out, it really should be called "Shut Down Media XXXXX" So in most cases, there's nothing you can do except send it off to a data recovery service and be prepared to shell out a bunch of money.
How to format the microSD?
actually u shold format it by the device in which u are going to use. eg camera. This will enable correct formating for usage of this device.
otherwise their is a standard Sd format and u can use that to format
You can format the card by SD card Utility. SD utility is a format utility which is release from SD Association. It is a standard for all SD type card and will self determine the SD card's file system. Please kindly refer to the link below for SD format utility download webpage.
http://www.sdcard.org/about/downloads/
My memory card is not opening
Your card may not be formatted -or- it is and it;s a proprietary format. If you want to format it, here is the instructions (for Windows):
Put your card into your computer (some have a slot or else use a card reader). Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
Memori terkunci
Saya akan membantu , tapi sebelumnya bolehkan sya bertanya :
1. Apakah ada data penting di dalam memori tersebut ?
Password sd
- Go to file manager on your mobile
- In Settings choose system folders,
- In the System folder, find a file called mmcstore
- Send the file to your PC using IR/Bluetooth
- Open the file in Notepad
- The password you need for your memory card is located within that file
Flash disk tidak bisa diformat...malah
- Pertama-tama buka Run >> cmd
- Kemudian ketikkan command berikut ini :
chkdsk g: /fKet :- g: [adalah path/direktory flash disk kita]
- /f [Fixes errors on the disk]
- Tunggu sampai proses berjalan, jika muncul command
Convert folder to file <Y/N>?[ketik] Y- Jika proses ini berhasil sampai 100% maka kita tinggal delete file/folder yang corrupt tadi.
