20 Most Recent
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Questions & Answers
How can I bypass my own password?
A password supposed to save guard your drive. What good would a password be, if you could override it?
There are programs on he net, that could unlock a password protected file or drive, but only as long as the password is simple. That means just a few characters. As long as you don't have acces to the programs the secret services of the world suppose to have, you won't be able to access your jump drive. Sorry
Pdf files on my flash drive won't open
Try to get a later copy of Adobe reader or get "Open Office" from GNU and try to read it Microsoft software is prone to do this out of my own experience and made me swear like a proverbial sailor
Cant boot from usb. sandisk cruz 4gb
These answers are garbage. You should be using "Roofus," you won't have to do any of that fancy formatting stuff. You can just select the drive and ".iso" file in the program and begin burning. https://rufus.akeo.ie/
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
Can't format my sandisk micro cruzer 16gb flash drive
Try this --
Download the HP disc format tool using this link--
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
After downloading the file you need to install this.
After installation,launch the software, and select the Flash Drive Letter and try formatting.
If this does'nt work,plz let me know and I'll give you one more alternative.
Pen drive not detected by my laptop
Your AV software may have created an block for your drive for some reason. You'll need to go in there and remove that block and then you should make an exceptionso it does not see your pen drive as a threat again.
4 gb usb creating shortcuts
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
My memory card showing recyclic error
Copy all the files onto your computer.
Then reformat the card, to identify and bypass the "bad" spots of memory. Note that flash-drives have a limited life-time -- after too much usage, you will be able to "read", but not "write" to the device. This is a sign that the device is "dying", and should not be trusted with "valuable" data.
Can a sandisk 16gb flash drive be repaired?
Try the flash drive in another computer, and if the problem is still there, the product may be corrupted.If the product is still in it's warranty period, you should go to the manufacturer's service center, and they will replace it free of cost. If the warranty period is over, just buy a new one.Hope this helps, Mrityunjay.
I m getting problem with
I m getting problem with IOCTL error with my sandisk 1gb pendrive..i m unable to format of open..will u plese send me solutions how to get rid of this error...??
Remove Write Protection
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
